It is currently Mon Dec 10, 2018 12:37 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 103 posts ]  Go to page 1, 2, 3, 4, 5 ... 7  Next
PostPosted: Wed Nov 14, 2018 6:44 am
Looking to upgrade my digital interconnects (coaxial) from the amp to my CD player. Any recommendations on which reasonably priced cable I should use? I was looking at AudioQuest Cinnamon Coax cable..just wondering if anyone here has used it before?
PostPosted: Wed Nov 14, 2018 7:11 am
Bank whole: Blue Jeans Cable Belden 1694A: https://www.bluejeanscable.com/store/digital-audio/index.htm
Bank rattled: Wireworld Silver Starlight 7: https://store.wireworldcable.com/collec ... =985660007
Very pleased with my Furutech 1.5 m. cable,well constructed at the price point.
PostPosted: Wed Nov 14, 2018 7:14 am
Amplifier Surgery off eBay
https://www.ebay.ca/itm/5FT-SILVER-PLATED-OFC-DIGITAL-COAX-RCA-AUDIOPHILE-AUDIO-CABLE-S-PDIF-SPDIF-USA/202067501075?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2649
Sold a Nordost Silver Shadow for this cable.
PostPosted: Wed Nov 14, 2018 7:43 am
Post edited by mod to remove banned content. PM sent.
Good question, regarding what's good; I recently discovered (in my set-up) the available AES/EBU (XLR 110-ohm balanced) to be significantly superior. If that option exists for you, consider exploring AES/EBU/Balanced digital cables. Actually (come to think of it), AQ 'Cinnamon' AES/EBU is the first XLR-style cable used -and it is quite nice.
It you wish to experiment (or simply save some money), look for a RCA-end (coax) 75-ohm video cable for digital duty.
pj
P.S> I just received a BNC (75-ohm) WW 'Starlight 7' -but have not ha a chance to evaluate.
PostPosted: Wed Nov 14, 2018 8:38 am
I recently purchased this cable and I was truly blown away. Better than the Atlas Compass and Wireworld Starlight #7, that I previously used. It's also on sale at 51% off. Make sure that you get a 1.5M length digital cable as the longer cable always sounds better.
https://www.futureshop.co.uk/qed-refere ... tom-length
PostPosted: Wed Nov 14, 2018 8:43 am
Blue Jean Cables. 100%
PostPosted: Wed Nov 14, 2018 8:45 am
The Wireworld Starlight digital coax is probably the best bang for the buck cable across their entire line of cables.
Davidson Home Audio Designs
PostPosted: Wed Nov 14, 2018 8:53 am
ruecatinat wrote:
Plus 1.
I have upgraded all the interconnects in two of my systems to Amplifier Surgery cables. Amazing difference. I replaced and sold all my Audioquest stuff because of them. These are really great cables and are at a price that does not break the bank. Don't let the Ebay "thing" scare you off; these are seriously good cables.
PostPosted: Wed Nov 14, 2018 9:02 am
That's cuz belden can't make a coax to save their lives!
(jk!)
PostPosted: Wed Nov 14, 2018 9:16 am
Many pieces of equipment have one digital input that sounds better then the rest, so if you have options, play around first to see what is the best sounding connection on your gear. In the past I have played around with different digital cables to compare & I would say they can sound slightly different. I have heard the AQ cinnamon & for the price, don't think its a bad cable, I'd probably call it neutral sounding cable. My personal preference (a bit more new but if you can find a used one they can normally be had for a good price) was an Oyaide DR-510 (believe list at $240 for a 1.3M). I'd say compared to the AQ, slightly smoother more refined but not lacking any details. Also compared the Kimber DV-30, I found this one a bit more detailed but also slightly more forward at the same time.
What ever you go with, get a 1.5M length (Oyaide only comes in 1.3 but still seems to work great), which is supposed to sound better then shorter lengths. I currently use AES/EBU in my main setup as this is the best sounding connection & for me Siltech has been the best I have heard but it's not in the same price category.
PostPosted: Wed Nov 14, 2018 9:17 am
pj
Balanced xlr is for long distances.
in short distances, in measurement, in theory, and in practice, they have higher jitter than standard single ended coaxial designs. Inescapably so. The problem comes when no two cables or cable types are the same, so it becomes a crap shoot. But the underlying jitter comparison remains as a fundamental truism.
The basic balanced or xlr format digital cable spec is all about function in/over long distances, it says nothing about jitter. thus, with long distances, balanced digital is notably jitter prone. re-clocking long balanced digital is the way to go. It's mostly for concert and mobile configurations, where a low functional failure rate is highly desirable and demanded, well beyond any concerns of jitter.
Jitter was so bad in the original balanced designs that their being non functional period, was an actual concern. they had serious limits. Like that of HDMI, with the twisted pair design aspect. HDMI originally had problems going beyond 12-15-20 feet. All laid at the feet of jitter. Both still wrestle with jitter problems, moreso than coaxial single ended does.
PostPosted: Wed Nov 14, 2018 9:56 am
Speaking of which; I have a new 'Starlight 7' BNC/BNC, but require a BNC-to-RCA connector (for CDP connection).
If you know, where could I purchase one ?
Thx,
peter
-- 14 Nov 2018 17:57 --
pj
P.S> I just received a BNC (75-ohm) WW 'Starlight 7' -but have not had a chance to evaluate.
-- 14 Nov 2018 18:02 --
Ken: Interesting theory; I very recently used a AES/EBU digital cable (of far lower quality than some of my coax digital) and it is waaaaay better than 75-ohm coax.
Clarity, dimensionality and tonal qualities are far superior.
so much for "theory".
pj
PostPosted: Wed Nov 14, 2018 10:05 am
https://www.ebay.ca/itm/1x-2M-Tributari ... 2934602441
PostPosted: Wed Nov 14, 2018 10:14 am
@allhifi Any Wireworld dealer will be able to have a cable made by Wireworld with any combination of rca/bnc ends. There is no extra charge as far as I am aware of.
