It is currently Mon Nov 19, 2018 1:33 pm
PostPosted: Fri Nov 09, 2018 8:56 am
In my listing 649474638 Sennheiser HD600 over ear headphones, I have posted incorrect information in the Additional Information section.
Would it be possible to delete it so that I can repost?
Thanks,
Mark
PostPosted: Fri Nov 09, 2018 9:14 am
https://www.canuckaudiomart.com/faq.php
Under For Selling
How do I modify my ad?
Once registered and logged in, click on the "My Ads" link on the User Navigation Bar located at the top right-hand corner of the site. You will be shown a list of all the ads you have posted. You are each given the option to "Manage Images", "Edit Ad" or "Mark as Sold". Just click on "Edit Ad" for the appropriate ad from that screen.
You will be taken to a form which has the current information from your ad which you have already filled in. Proceed to modify the fields accordingly. When finished, click on the "Update" button. You should then see confirmation text if your ad was successfully modified.
Note that Ad descriptions and captions can be freely modified for up to 12hours after they are posted. Afte rthis initial period, ad descriptions and captions can be expanded or changed slightly. You can also add "additional" information by using the "additional information" field when editing.
https://www.leohl.ca
Site Admin
I have removed both additional info sections of that ad. Go ahead and try to add the correct info
PS: AudioOhm's information is also very helpful, I believe the "Additional Information" fields are unlike the regular fields in that they cannot be edited once added.
PostPosted: Fri Nov 09, 2018 10:25 am
This is unfortunate. I placed info regarding a trip under additional info in my ads noting that I could deliver, and now that that trip is done I cannot remove it.
PostPosted: Fri Nov 09, 2018 11:09 am
Site Admin
You can post the ad id here and we can remove that trip info.
