It is currently Wed Dec 12, 2018 9:25 am
PostPosted: Mon Nov 05, 2018 2:50 pm
Anyone know of repair shop to handle above. Naturally I want JL parts if required. I think it’s just a volume switch problem
PostPosted: Sun Nov 11, 2018 3:56 am
Bay/Bloor were once dealers (I believe), so I’d try contacting them.
PostPosted: Sun Nov 11, 2018 5:33 am
Unless its covered under warranty I'd save myself the arm and leg and take directly to a tech. Hence OP's reason for seeking help I presume.
You can try here http://www.dtsaudioelectronics.com/Repairs.html.
What makes you think its a faulty volume? Are those digital step or analog? An analog should be pretty easy to change if you can solder and turn a screw driver.
PostPosted: Tue Nov 13, 2018 9:34 am
PM sent. Anyone who is having issues with their JL sub (especially the E110's) should email service@gemsen.com. They will steer you in the right direction. I even received a refurbished amp out of warranty. Great service!
PostPosted: Tue Nov 13, 2018 10:21 am
I had both of my F110 Fathoms fixed at:
Rick Turcic ● Ontario Audio/Video Service Inc. ● 2074 Steeles Avenue East, unit 21 ● Brampton ON ● Canada L6T 4Z9 ● PH.905-791-2020, FX.905-791-2121, TF.888-791-2899 ● rick@ontav.com
Recommended by Gemsen, Jl Audio and PS Audio.
They also fixed 2 tube preamps for me.
PostPosted: Tue Nov 13, 2018 1:23 pm
Thanking you all for your replies. I have sent them all an email
-- 13 Nov 2018 17:23 --
PostPosted: Tue Nov 13, 2018 4:46 pm
You may find this thread useful: viewtopic.php?f=6&t=48528&p=772728#p772728
Seems there was a massive problem with volume knobs on E110 subs. I had both of my amp boards replaced under warranty to address the problem.
PostPosted: Thu Nov 15, 2018 6:52 am
Fixed!! Thanks to 347strokin for input. As you may all know, there’s no fixing, just replacing. Had the amp unit replaced, it only took 15 minutes. Here’s the contact.
Gem-Sem Holdings Corp
266 Applewood Cres. Concord Ont.
T-1 905-660-3110
Ask for Joe, was a great guy to deal with.
