It is currently Wed Oct 17, 2018 2:30 am
 Post subject: Geometry a RB330 arm
PostPosted: Thu Oct 11, 2018 10:06 am
I am about to set up a buddies new Rega P3 with a Dyna 10x5 cart. Now I know about the VTA, my question is; can I set the RB330 arm with the Mint protractor that I have for my RB300 arm? :?
Doug
 Post subject: Re: Geometry a RB330 arm
PostPosted: Thu Oct 11, 2018 10:23 am
Yes, both the RB300 and RB330 have a spindle to pivot mounting distance of 222mm.
PostPosted: Thu Oct 11, 2018 10:25 am
I am pretty sure they are both 222mm pivot to spindle.
PostPosted: Thu Oct 11, 2018 11:26 am
http://www.rega.co.uk/rb330-tonearm.html
Effective mass - Low / 11g
Overhang 17.2mm
Mounting distance platter center to arm hole center 222mm
PostPosted: Thu Oct 11, 2018 3:24 pm
Thank you for your replies. I was aware of the mounting distance of 222mm, but the effective length is 227mm for the RB330, while the RB300 is as we all know, is 239mm. So this got me confused and threw me for a loop!
Doug
PostPosted: Thu Oct 11, 2018 4:10 pm
Doug
The RB330 overhang/effective length numbers are indicative of a Baerwald alignment (or at least something very close to it). On the other hand, the 15 mm overhang and 237 mm effective length spec on the 300 are a Rega proprietary alignment which is closer to Stevenson.
Unless you specified a custom protractor from Yip, he probably supplied you with a Mint based on the 300 specs for your 300. That would not stop you from using it on the 330 as long as the slots in the headshell allow you the room fore and aft to secure the cartridge to achieve the proper alignment. But you'd be aligning, in that case, with the Rega alignment (closer to Stevenson) as mentioned above, as opposed to the Baerwald alignment.
