It is currently Wed Dec 12, 2018 1:13 am
 Post subject: Can this Amp be Bi-Wired
PostPosted: Mon Oct 01, 2018 6:49 pm
Hi guys
I have a Stellar Labs SLA 250 Amp I’m giving to my 16yr old son and want to know if this amp can be bi-wired
I have added a photo for people to view and explain how to do this if possible
File comment: 2 sets of speaker outputs
PostPosted: Mon Oct 01, 2018 7:06 pm
Yes it can, you just have to respect the impedance recommendation on the manual when using A+B.
Balance MC-1010 phono stage... in progress (week 2)
PostPosted: Mon Oct 01, 2018 7:23 pm
Wouldn't the amp see the same impedance?
We're biwiring not biamping.
PostPosted: Tue Oct 02, 2018 4:05 am
Yes, it can be bi-wired. Might even be better like that.
See: https://www.qacoustics.co.uk/blog/2016/ ... -benefits/
Death is not the greatest loss in life. The greatest loss is what dies inside us while we live. Norman Cousins
PostPosted: Tue Oct 02, 2018 4:26 am
As previously mentioned, yes, as per the manual
A/B Speaker Selector
Each A and B pushbutton operates independently. Pressing the button in will engage the speaker pair for the designated output. Pressing again will disengage that output. With both pairs on, the speaker outputs are parallel.
PostPosted: Tue Oct 02, 2018 4:37 am
That's a big might imo...
PostPosted: Tue Oct 02, 2018 5:08 am
I tried to bi-wire a pair of speakers many years ago, using the A and B speakers connections on an Arcam FMJ A32 integrated amp, and the amp shut down due to its overload protection ... I assume that the impedance had fallen to less than 4 ohms
PostPosted: Tue Oct 02, 2018 5:23 am
To Phil,
You shorted the amp output if the links are there and reversed plus and minus wires?
Or you just might have forgot to remove the jumpers that bridges upper and lower speakers connections at the speakers
connection posts.
To OP,
But in fact it is the speakers connections that are bi-wired. As such, both lower and upper speakers posts refereed to the amplifier output
single speakers posts, this is to obtain lower impedance paths; (tweeter/mds section are less affected by woofer back EMF: considering your amp have very low output impedance or high damping factor).
Of course this is always amp/speaker matching and if you can discern an improvement by doing bi wiring.
PostPosted: Tue Oct 02, 2018 5:40 am
BigBill6778,
Bi-wiring can be done with any amp as long as your speakers are bi-wireable [Speakers have high and low posts]
I believe you're wanting to bi-amp using 2 pairs of speaker outputs. It can be done but with caution. As it is for your 16 year old son I would advise against it.
Google bi-wiring Vs. bi-amping.
Audiois1st
Check me out: http://www.canuckaudiomart.com/userprofile.php?user_id=39933
PostPosted: Tue Oct 02, 2018 5:42 am
A visual aid might help.
G
PostPosted: Tue Oct 02, 2018 6:15 am
revoxb77 wrote:
To Phil,
connection posts.
No, I definitely did not reverse the plus and minus (red and black) wires, and the jumpers were definitely not in place on the speakers ... reading the Arcam A32 manual on line a few minutes ago, it cautions against bi-wiring using the A and B speaker post on the amp because indeed it can fall below 4 ohms and set off the protection circuit .... and that is what happened ... so I guess it depends on the particular speaker being bi-wired
PostPosted: Tue Oct 02, 2018 9:50 am
Phil Jones wrote:
revoxb77 wrote:
To Phil,
connection posts.
Curious. I can see an additional pair causing this, but not just the one.
PostPosted: Tue Oct 02, 2018 1:24 pm
Protection would trigger on 2 pairs of 4 ohms speakers causing 2 ohms load.
Or a pair of 4 ohms and an 8 ohms giving 2,67 ohms again a bit too much.
PostPosted: Wed Oct 10, 2018 2:25 pm
Bi-wireing is only benefitting cable manufacturers. Bi-amping is whole another thing which can have substantial sonic benefits IF used with crossover before power amps.
PostPosted: Wed Oct 10, 2018 2:43 pm
And we thank you for your opinion.
