It is currently Tue Oct 16, 2018 5:01 pm
Post new topic Reply to topic  [ 29 posts ]  Go to page 1, 2  Next
PostPosted: Wed Sep 26, 2018 10:32 am
Just want power in, power out. Nothing fancy like filtering, etc.
Was looking at one of these: https://www.planetofsoundonline.com/col ... aide-mts-6
PostPosted: Wed Sep 26, 2018 11:05 am
Recently I purchased a Supra power bar from Madisound,I am extremely happy with the quality of construction you will require an IEC power cable but I put mine together for less than$120 US total using all Supra parts the bar is $89 US discounted from $260 US and I think its a bit of a deal.It is a little more full function than the one you are looking at.Perhaps you won't like the switch, lights,and circuit breaker.I just checked and they are still available.
PostPosted: Wed Sep 26, 2018 11:12 am
APC or Emotiva are straighter-shooter, quality pieces of gear. I would highly, highly recommend either.
Keep in mind that power bar doesn't mean it includes surge protection...
PostPosted: Wed Sep 26, 2018 11:13 am
http://www.hammondmfg.com/1584h.htm
https://www.hammfg.com/electrical/distr ... /canada/on
Sorry, Mister Vice President, 'The Handmaid's Tale' is not a documentary.
PostPosted: Wed Sep 26, 2018 11:51 am
Look for clearance and blowouts from shops like this.
https://www.staples.ca/en/Tripp-Lite-Po ... 0001/zxx8v
G
PostPosted: Wed Sep 26, 2018 11:55 am
Quadzilla wrote:
I have a few of these. No B. S. brilliant
PostPosted: Wed Sep 26, 2018 11:57 am
I forgot about the brands above but think they're also certainly worthy of consideration - great stuff.
The Isobar stuff specifically is supposed to be quite good albeit I don't have experience
https://www.staples.ca/en/tripp-lite-is ... gKR2fD_BwE
PostPosted: Wed Sep 26, 2018 12:24 pm
tommyboytp wrote:
I have a few myself. I like that they don't have power switches or circuit breakers … just a sturdy metal housing with a quality hospital-grade wall plug and outlets. They aren't named after Norse gods, they don't have groovy silk-screened black hole logos, and they don't claim to have magic life-changing laxative-salt ground circuitry. They just work … and the OP can buy a couple of them with his budget.
PostPosted: Wed Sep 26, 2018 2:07 pm
If you can get away with 4 outlets, perhaps one of these? Or if you have two wall receptacles within reach of all your gear, two of these. I've used one for years now, as I only have 4 audio components to power. Hospital grade, and eliminates the need for another length of power cord. The unit mounts directly to your wall outlet.
https://www.ebay.com/itm/NEW-Hubbell-HB ... Sww85aU5pZ
PostPosted: Wed Sep 26, 2018 2:11 pm
Great solution. I use APCs in my house (three of em) and they have saved my systems a couple of times. And with the added benefit of a full buffer between the wall and your system. Nothing but good, clean power within very tight tolerances. And you are feeding all your system from a single source so all equipment is seeing the same power delivery. The sound floor drops to zero, nothing but clean sound. The best couple of hundred bucks you can spend.
PostPosted: Wed Sep 26, 2018 2:33 pm
UHF Power bar with green dot hubbells
or
holee blowin smoke batman
go to home sometin and buy yourself
some spec grade hubbells, a box, a few feet of wire
and save about 250 or so.....
this aint rocket science.
a spec grade+ in the wall too please.
and perhaps some decent power cable from tfa or as or others.
a decent electrician can whip this up in an hour.
yes it will take longer than that for us mortals.
PostPosted: Wed Sep 26, 2018 2:36 pm
I am using this one from Furman, they have a great reputation and are very reliable.
https://www.electronicsforless.ca/furma ... -1038.html
PostPosted: Tue Oct 09, 2018 7:34 pm
To the OP...
Tripp-Lite Isobar (Ultra - if you want).
I use five of them in my main HT to protect all of my gear.
Available with 4, 6, 8 (and maybe more) outlets.
Rock solid. Bullet proof. And yes, they all have surge protection. But why would you not want that?
And even the 8 outlet is $80C - or less.
Very much a no-brainer.
Jeff
Available now: Most of These Stories Are Somewhat True - a collection of 107 short stories based on my life and travels. http://www.jeffmackwood.com
PostPosted: Tue Oct 09, 2018 7:41 pm
Sorry, not sorry I just got the last one of these :)
https://www.amazon.ca/gp/product/B00005 ... UTF8&psc=1
Tripp Lite ISOBAR6ULTRAHG 6-Outlet Hospital Grade
PostPosted: Tue Oct 09, 2018 8:02 pm
I'll add a + to the Tripp-Lite Isobars...
I've a couple of the 6 outlet boxes, that came with Hospital grade Hubble's, and they're very solid, inexpensive power bars. The fact that Active was discontinuing them, and I got them for about $40 each made them a complete no brainer!
Good luck! Dave
