It is currently Tue Dec 11, 2018 10:54 am
Do You Unplug Your System During A Storm?
Yes, Without Exception 12%  12%  [ 14 ]
Sometimes, Depending On The Storm 40%  40%  [ 46 ]
No, I’ve Got Adequate Surge Protection 32%  32%  [ 37 ]
No, I’m Well Insured 16%  16%  [ 18 ]
Total votes : 115
 Post subject: Poll: Do You Unplug?
PostPosted: Fri Sep 21, 2018 1:18 pm
In Southern Ontario we have had quite a few storms blow through this summer. In fact, one is underway as I write. I’ve gotten into the habit of unplugging my system before the storm hits, as long as I am around to do it. I have some surge protection but I would rather err on the side of caution.
How about you?
 Post subject: Re: Poll: Do You Unplug?
PostPosted: Fri Sep 21, 2018 1:28 pm
Storm or No Storm, I Always unplug All my components right after a listening session,As I have learned from experience a unplanned or unexpected power outage can happen at anytime.
PostPosted: Fri Sep 21, 2018 1:29 pm
I never unplug.
How would you unplug if you are not home during a storm?
https://www.leohl.ca
PostPosted: Fri Sep 21, 2018 1:30 pm
Good timing, as I sit here, listening to the tornado warning for my area! The gear is turned off, but not unplugged. Some is effectively unplugged by the power bar/surge protector (relay's that cut power to some outlets), others by the remote trigger power on (which does mean some portion of the gear is powered up).
Mostly I'm just too lazy!
PostPosted: Fri Sep 21, 2018 1:44 pm
AudiOhm wrote:
I never unplug.
Ditto.
PostPosted: Fri Sep 21, 2018 1:52 pm
I unplug when I leave for any trip over a day or 2 or when lightning is happening but other than that no
PostPosted: Fri Sep 21, 2018 1:55 pm
whole home surge protection at the boxes.
PostPosted: Fri Sep 21, 2018 2:51 pm
most of the time all is powered up but I keep a close eye on the weather if it looks like trouble I un plug and always power down when I leave for a holiday
PostPosted: Fri Sep 21, 2018 3:37 pm
Each mono blocks has four 300 b tubs a 6sl7, I run 5691, and an el34... So yes I physically unplug those after every session
The rest of the system and surround are on ps audio protection so hopefully that will do its job if ever such an event takes place
PostPosted: Fri Sep 21, 2018 5:00 pm
lol. I spend way too much time watching the weather network. Any weather pattern that may bring a storm and everything is shut down and unplugged. No time left for real tv shows.
PostPosted: Fri Sep 21, 2018 5:21 pm
Old Rusty wrote:
AudiOhm wrote:
I never unplug.
Ditto.
Mystery resolved; the original poster said he unplugs if he is around to do it.
PostPosted: Fri Sep 21, 2018 6:55 pm
How about you?[/quote]
I just finished putting surge protectors on a few outlets.
My 5 yr old LG tv without many hours had the panel die a few weeks ago,
and I think it's due to bad Hydro in my area. I had only 1 out 3 HDMI Ports working on that TV when it pooped out.
My Living room/ wall where my sound system and TV are, is directly behing the Power Box in the Garage. I have nowhere else they can be put.
All these Surge suppressors indicate that they must be placed at least 30 feet(of wiring) away from the Box, and I'm sure warranty won't apply because I' way closer that that, but I put them in anyway.
TV seems to be very sensitive, so I'll pull the plug on that during storms.
Everything else is on another Surge protector, if it's bad enough I can power it down.
I was posting this reply at around 6 PM, but my power went out :cry:
Ott.
PostPosted: Fri Sep 21, 2018 7:28 pm
Posting in the dark as the power is still out...
I hit the switch on the power bar / conditioner but don’t unplug —- too lazy as an earlier poster stated, so not one of the options so didn’t pick any.
PostPosted: Fri Sep 21, 2018 9:51 pm
Old Rusty wrote:
AudiOhm wrote:
I never unplug.
Ditto.
Unless you power off before you go out, if weather is expected or as a matter of course, I am too lazy to think of that though.
Ott.
-- 22 Sep 2018 05:53 --
I am actually thinking about that!
Ott.
PostPosted: Sat Sep 22, 2018 3:51 am
I believe the weatherman has gotten into the habit of dramatizing everything. Nevertheless, only when he calls for severe storms and it looks probable that I will unplug. Otherwise, as I've said in the past, I will preferably put on The Doors' Riders On The Storm and enjoy the ambiophonic experience. Besides, experience has shown that I usually have power failures on a bright sunny day. And when that happens, that's when I pull the plug.
Users browsing this forum: Babrbarossa, copo, guzziguy56, Priyo and 10 guests
