It is currently Fri Oct 19, 2018 9:56 pm
PostPosted: Sun Sep 16, 2018 1:30 pm
Hello on this fine Sunday afternoon, I'm in a bit of a pickle. I just got some Kimber Kable 12TC and I need to re terminate for tri wiring my speakers, the problem is I don't know which is the amp end and which is the speaker end? any help would be greatly appreciated.
PostPosted: Sun Sep 16, 2018 2:24 pm
When last seen, Ray Kimber didn't believe in cable directionality.... and so his cables have never had arrows on them... He feels that the construction of the cable, and the constructions affect on series inductance and capacitance, is the important part, not which way the wire was pulled through the die (and if you can actually guarantee the direction, given that almost no cable makers actually make their wire stock).
PostPosted: Sun Sep 16, 2018 2:27 pm
Thank you for that, I think I may have bigger problems. surfing the web for direction answers I stumbled upon "how to spot a counterfeit". Now I'm worried I have fakes.....
PostPosted: Sun Sep 16, 2018 2:58 pm
I think you can bi-wire easy with the gold,gold, white, white scenario....for tri-wire you would have to divide the number of wires etc....fake or real? Plug it in and hear what you hear....at this stage....
PostPosted: Sun Sep 16, 2018 3:03 pm
I was thinking 6 wires for woofer 3 for mid 3 for tweeter, or perhaps 4 to all three.
keep it simple the word kimber kable in the direction towards the speaker
PostPosted: Sun Sep 16, 2018 3:05 pm
Logic would normally dictate that however "Kimber Kable" runs to each termination.....
PostPosted: Sun Sep 16, 2018 3:06 pm
both seems to be OK. Depends on the speakers...if there is big woofers involved, you may go for the 6-3-3....
PostPosted: Sun Sep 16, 2018 3:08 pm
Thanks, I think a 12" woofer deserves 6 wires.....:)
PostPosted: Sun Sep 16, 2018 4:11 pm
How about using good quality jumpers and leave the cable intact
PostPosted: Sun Sep 16, 2018 4:53 pm
...Or run bare wire...less is more.. And direction made no difference
It's only when you see a mosquito landing on your testicles that you begin to realize there's usually a better way to solve a problem than resorting to violence.....
PostPosted: Wed Sep 19, 2018 4:50 am
Update, I got it all figured out. It took a bit of work and some adapters but it's done...:)
42090057_2251039678270670_1359839774659051520_n.jpg [ 156.86 KiB | Viewed 603 times ]
PostPosted: Fri Sep 28, 2018 12:14 pm
The best trick to do with this cable is to attach a cotton rope to a pencil and insert in nucleus of the cable. It has to be pure cotton rope. Yo will get a different cable, a lot more open in sound. Of course you have to remove the pencil later.
PostPosted: Tue Oct 09, 2018 5:27 am
Just wondering if your being serious? Also could Unicorn mane be a substitute for cotton?
PostPosted: Tue Oct 09, 2018 7:14 am
The answers are definitely yes and yes!
