It is currently Thu Nov 15, 2018 11:14 am
PostPosted: Thu Sep 13, 2018 9:45 am
I need I believe a Type A to Type B usb cable. what should I get and where to get it....preferably within Canada.
Thanks!
-- 13 Sep 2018 17:49 --
would this cable be ok to use?
https://www.monoprice.com/product?c_id= ... 1&format=2
PostPosted: Thu Sep 13, 2018 9:49 am
Amazon....$5
PostPosted: Thu Sep 13, 2018 10:00 am
Hi
A nice one priced reasonably is the Belkin Gold series hi-speed USB .About 25 dollars at Canadacomputers.
Cheers
George
PostPosted: Thu Sep 13, 2018 12:20 pm
Thanks!
I’ve used Monoprice cables before. They work fine. You could probably find something similar at Staples or even Princess Auto.
PostPosted: Thu Sep 13, 2018 2:08 pm
Sunshine is your friend.
G
PostPosted: Fri Sep 14, 2018 6:22 am
OP,
I recommend Audio Sensibility.
Audiois1st
Check me out: http://www.canuckaudiomart.com/userprofile.php?user_id=39933
PostPosted: Fri Sep 14, 2018 10:21 am
IMO, I'd forego the $5 or $20 cable that people are recommending and get a proper audiophile USB cable. Without getting into a cable debate, you can buy a good one from Audio Sensibility or Audioquest for less than $90. There is a difference in sound IMO.
PostPosted: Fri Sep 14, 2018 6:44 pm
Why spend good good money on a cable for a USB input when the folks that made the DAC admit it’s not the best? I have some good cables including Audio Sensibility but wouldn’t spend big money in this instance. The OP asked about a $2 cable, I’m guessing spending $100 isn’t his plan.
PostPosted: Fri Sep 14, 2018 7:21 pm
Sorry man but this is absolutely BS.
PostPosted: Fri Sep 14, 2018 7:52 pm
Oh, the horror...... :lol:
PostPosted: Sat Sep 15, 2018 2:16 am
Ticking away the moments that make up a dull day. Well made Well shielded. yes. Audiophile cash remover? no. :wink:
PostPosted: Sat Sep 15, 2018 5:34 am
I have just ordered one of these: No experience with it other than the quite positive reviews I found online. Time will tell, and I do think cables do make a difference much of the time (either you believe or not - but its all in the hearing is believing - right??)
https://www.canuckaudiomart.com/details ... -new-sale/
jp
ps no affiliation with seller
PostPosted: Sat Sep 15, 2018 5:42 am
One day closer to death.
G
PostPosted: Sat Sep 15, 2018 9:31 am
jp
Hi
DH Labs has a good reputation and reasonably priced ,I think you will like it.
