It is currently Mon Nov 12, 2018 4:13 pm
Post new topic Reply to topic  [ 43 posts ]  Go to page 1, 2, 3  Next
PostPosted: Thu Sep 13, 2018 3:55 am
USB in, digital output , without built-in DAC very simple
Any suggestion?
THX
PostPosted: Thu Sep 13, 2018 4:24 am
is it just a USB-Coax converter you need then? There are a few threads with comments on various models, including this one
viewtopic.php?f=35&t=51179
PostPosted: Thu Sep 13, 2018 8:49 am
No ....... not like that, I don't NEED the build in DAC!!!!
PostPosted: Thu Sep 13, 2018 9:49 am
Hi
Hard to find one with out bells and whistles but I recently became aware of the Brennan B2 server (500 dollars) very simple box . It has 2 (USB) 1 (micro USB) 1 (spdif out) .Check it at Thebrennan.com to see if it suits you.
George
PostPosted: Thu Sep 13, 2018 9:53 am
Auralic Aries could work of USB out is ok.
PostPosted: Thu Sep 13, 2018 10:17 am
there is no analogue signal that passes through it, thus no dac.
do you need a media player on the device?
PostPosted: Thu Sep 13, 2018 11:47 am
Actually a Squeezebox Touch would do this as well.
PostPosted: Thu Sep 13, 2018 12:13 pm
What about the Sony UBP-X800.
It's a transport - CD, SACD, DVD-A, DVD-V, BluRay.
It will play from a USB key or USB hard drive.
I don't think it will connect to a computer USB.
It has 3 outputs: coaxial, video/audio HDMI out and audio only HDMI out.
No built-in DAC.
You can play SACD and get DSD output from audio HDMI and into a DAC if the DAC has a HDMI input that will receive DSD.
All this and it plays movies too.
PostPosted: Thu Sep 13, 2018 12:25 pm
+1
PostPosted: Thu Sep 13, 2018 1:06 pm
Logitech Squeezebox Touch is NOT bad !! I need only transport ( I have 5 DAC!! ,so thats what I'm need just transport
Touch is able to read 1TB har drive?
https://www.stereophile.com/mediaserver ... index.html
PostPosted: Thu Sep 13, 2018 1:59 pm
Best bang for the buck I think is the Bryston BDP-1
PostPosted: Thu Sep 13, 2018 2:23 pm
Interesting question. I think it came out before there were drives that size. I have all my music on a server and play from that so I don't know.
Playing from an external HDD is always dicey and an issue for most transports.
PostPosted: Thu Sep 13, 2018 2:39 pm
Touch is pretty buggy with USB. I also wouldn't recommend it if you have music on a hard drive and not on a network.
PostPosted: Thu Sep 13, 2018 2:52 pm
I'm found this:
http://wiki.slimdevices.com/index.php/S ... patibility
PostPosted: Thu Sep 13, 2018 4:16 pm
No built-in DAC.
I was going to suggest the Sony BDP-6700.
But the remote is a bit toy.
For use with a USB stick, it will need an HDMI cable and a monitor.
Picture quality from this Sony unit, with regular 480p DVD's, is quite impressive.
However, for a smart TV, I use a chrome book with an HDMI port.
In terms of a CD or SACD transport, have you had a chance to compare any of the Sony units ?
Sony BDP 6700 vs UBP-X800 vs UBP-X1000es ?
Users browsing this forum: AHarris, little camaro, NickD and 17 guests
