It is currently Sat Nov 17, 2018 7:59 pm
PostPosted: Sun Aug 19, 2018 1:02 pm
Went to list a TRIODE 300B - RS and when I click on 'Place An Ad' nothing happens...same thing when I click on 'Upgrade Classifieds'
Never had this problem before...
0 of 5 posts today
0 of 20 posts this month
50 of 180 non-software posts in past 12
I cannot even change any of the Classified Filters...or reset them.
Tried logging out then logging back in...same result.
Happens in both CHROME and IE
HELP!!! :)
Anybody else experiencing this problem?
I Put A Spell On You!!!
PostPosted: Mon Aug 20, 2018 9:44 am
Site Admin
We just discovered and fixed a bug that *could* be related to what you're experiencing - can you check and refresh your page to see if it's resolved?
Otherwise, if you refresh pages and the bug still exists, then this sounds like a Javascript problem, which can be caused by many things including:
* Ad blockers
* Firewalls
* Internet issues
* Our CDN
* A bug on our end
In Chrome, can you right click on the page where you have problems, select "Inspect", go to the Console tab, and then refresh the page. Now, try clicking the Upgrade or Place an Ad buttons again. If you see any text in red that could be related to the problem, so post a screenshot of that Console.
PostPosted: Mon Aug 20, 2018 1:57 pm
Ad Blocker...now disabled!!!
Thank you. :)
PostPosted: Mon Aug 20, 2018 3:15 pm
Site Admin
Thank you. :)
Can you tell me what ad blocker was causing this? I'd like to see what they were blocking and why, seems they are being overly aggressive and blocking legitimate functionality.
You also mentioned this was happening in Chrome and IE, were they using different ad blockers and what were they?
PostPosted: Mon Aug 20, 2018 3:20 pm
Privacy Badger in Chrome...
Not certain what the ad blocker is in IE as I never use it...
PostPosted: Tue Aug 21, 2018 10:46 am
Site Admin
I just tested Privacy Badger and it's installed defaults don't block our critical files, but Privacy Badger has been a problem in the past with incorrectly identifying and blocking non-ad and non-privacy related files, it's not consistent in how it does this so it might or might not break CAM. It also seems to change its behaviour from version to version. I recommend turning off Privacy Badger on CAM to be on the safe side.
PostPosted: Tue Aug 21, 2018 11:02 am
Done!!! :wink:
PostPosted: Tue Aug 21, 2018 11:12 am
Try a Honey Badger....maybe it'll have a sweeter disposition....er, or maybe not...
-- 21 Aug 2018 15:14 --
you might wind-up with this one!
