It is currently Sat Oct 20, 2018 12:05 am
PostPosted: Sun Jul 08, 2018 7:35 am
for those who didn't get the email or missed on the last order.
https://diyaudiostore.com/collections/k ... 2933085218
PostPosted: Sun Jul 08, 2018 8:42 am
Thank you. Ordered. It'll be the first time in my life. Let's see :-D
PostPosted: Wed Aug 08, 2018 4:36 pm
I did the previous order. Everything has arrived and looks to be great quality; especially the case; everything fits perfectly, all the holes are drilled, tapped, etc. I expect the kits will go together just as well as the cases. Happy man here! :D
PostPosted: Thu Aug 09, 2018 3:27 pm
brownslane wrote:
I did the previous order. I have been "back-ordered" for two months now. They keep promising delivery and then cancel it, blaming backordered components. This is getting a little tiring. I hope you are more successful. On a positive note, the two chassis have arrived (I ordered two so I can mono them) and the quality of construction is flawless.
I got an email with tracking number on the weekend. Left the States on the 5th, hasn't been updated since.
They said I was one of the first to be shipped out, but I assumed they said that to everyone lol.
PostPosted: Thu Sep 13, 2018 9:06 am
I got the casing !! :mrgreen:
Ordered something like only 5 days ago.
Not opened yet, but we can clearly see : Made in Italy
Big thanks Gianluca :wink:
PostPosted: Thu Sep 13, 2018 9:57 am
Mik, is this for my power supply? :P
PostPosted: Thu Sep 13, 2018 10:42 am
Yes, Sir
And apparently, the transformer is in production.
You will have a fresh made one.
8)
PostPosted: Wed Sep 19, 2018 8:13 am
And now I got the transformer, woo-hoo !
Look that beast, under is the casing bottom plate. It will fit tight... as expected. It is exactly as wanted.
That power supply is going to be heavy, powerful, quiet, performing and dedicated to the ACAs.
Well, and very nice :mrgreen:
PostPosted: Wed Sep 19, 2018 12:06 pm
Looks impressive.
I take it that it needs its own case?
PostPosted: Wed Sep 19, 2018 12:39 pm
ripblade wrote:
Looks impressive.
Yes.
It's why I chose the biggest transfo as possible. It is 350va 2x 22v AC 2x 8 amp.
I measured it at 385va.
Do not forget that it will drive 4 channel (2 ACA's bridged).
Some quick math, the original SMPS is 150va. So x2 = 300va.
But since I will cut at least 25va for 2 channel (50va total) we are around the same power.
Of course the goal is to do better than the SMPS, we'll see if I can do that.
Once done, I will of course share here the schematic.
The big lines are : clipper, current reg, voltage reg and two separated capacitor blocks.
One block will be inside each ACAs as the capacitors must be the closest as possible to the output transistors.
And since the ACAs are mostly empty... there's room to do it.
Having the big transfo far and isolated from the amps will give the last bit of transparency.
Well, I hope.
DC output will be: 2x 23 to 27 volts 5 amp adjustable and floating ground.
Later
PostPosted: Thu Sep 20, 2018 6:52 am
I find this totally fascinating. Anyone completed this project and care to share thoughts?
PostPosted: Thu Sep 20, 2018 7:22 am
what is an ACA?
PostPosted: Thu Sep 20, 2018 9:09 am
ACA stands for Amp Camp Amp after an amplifier camp run by Nelson Pass.
Users browsing this forum: Google [Bot] and 10 guests
