It is currently Tue Jun 19, 2018 11:57 am
Post new topic Reply to topic  [ 58 posts ]  Go to page Previous  1, 2, 3, 4
PostPosted: Thu Mar 08, 2018 6:48 am
I'll let outfire tell you what it was ... once it's done that is.
-Chris
PostPosted: Thu Mar 08, 2018 5:26 pm
I don't know what the other tech is saying but there re tons of distortion. I will see you on Saturday Chris.
PostPosted: Thu Mar 08, 2018 6:50 pm
See you then. Drive carefully.
-Chris
PostPosted: Sun Mar 11, 2018 3:41 pm
The amp is fine. Chris had tried to create issues but he could not find a fault on the amp. he drive the amp into clipping but the distortion is max to be 0.05
PostPosted: Sun Mar 11, 2018 3:54 pm
Well... now you have an issue with one other component or your connectivity. Try your other component with a different amp.
PostPosted: Mon Mar 12, 2018 2:41 pm
now i have to trace down who is the one to blame.
PostPosted: Mon Mar 12, 2018 4:09 pm
So far I wiggle around with the RCA cables and speakers cable while playing music and everything seem fine.
PostPosted: Mon Mar 12, 2018 4:55 pm
From your very first post, you said "channel 2 cuts out".
What is channel 2, the right channel ?
If yes, plug everything form right to left, inputs, speakers... to see.
And, you should try to explain to us the best as you can the "cuts out".
I mean, does the cut is dry and instant (complete cut) or some sound
can be heard when cutting. Also did you noticed that the sound come back
without having to power off/on ?
PostPosted: Mon Mar 12, 2018 5:08 pm
Hey Nakamichi. My old lover stasis amp. I now believe it has nothing to do with the amp or the cables. I think it is more of the preamp and the dynamic volume setting.
I turn off dynamic volume and there are no distortion that I can detect. Vocal is clear. Bass is tight and define even though it is satellite speakers lol. My baby is sleeping right now so cannot further the test at a high volume. Since I can't detect any distortion, I don't think it will at high volume.
-- 13 Mar 2018 01:10 --
Channel 2 is the center channel
PostPosted: Mon Mar 12, 2018 5:11 pm
Ok then :D
PostPosted: Mon Mar 12, 2018 6:48 pm
Hi Mike,
I see you called. I will be resting for a few days as I had a root canal done today. Still hurts a lot, there was a big abscess. Started Friday and by Monday I can't do anything.
It's not comfortable to talk, so give me a couple days. They finish on Thursday (yahoo)
-Chris
PostPosted: Fri Mar 16, 2018 5:05 pm
let me know when i can call you
PostPosted: Sat Mar 17, 2018 1:06 pm
Hi Mike,
Procedure delayed to Monday, so maybe Tuesday. I'm all swollen due to an infection. This is the first time I've had problems with a root canal. It's still pretty painful.
You can send me an email of course.
-Chris
Users browsing this forum: Alharcourt and 5 guests
