> Classifieds > > > Anthem STR Integrated Amplifier Stereo integrated amplifier with built-in DAC & Anthem Room Corr
SOLD - FOR SALE: Anthem STR Integrated Amplifier Stereo integrated amplifier with built-in DAC & Anthem Room Corr
Item #649459597
Info: Anthem STR Integrated Amplifier Stereo integrated amplifier with built-in DAC & Anthem Room Corr
USD $2850.00
Retail Price: USD $4500.00
Payment method: Cash, Paypal
Ships to: United States
Shipping weight: 24.95 (kg) Calculate Shipping
Shipping Dimension: 55.88cm x 55.88cm x 43.18cm
Condition: 9 - Excellent (?)
Date Posted: Sep 03, 18 1:13pm (PST)
Edited: Sep 26, 18 9:19am
About Seller: AVTONY2510
Fort Worth, TX
[other classified ads]
Product Brand: Anthem
Product Model: STR Integrated
Feedback Received: 3  See details
100% Positive Feedback
External Feedback: tony2510 (589)
PayPal:
Days in System:23
Avg. Views/Day:10.74
Anthem STR Reference Integrated (Like New)
Up for Grabs, the newly released Anthem STR Integrated.
Purchased new Nov 2017 from Crutchfield. Still under warranty. I have the receipt. In Excellent Condition with the Original Box and packing material. Comes from a smoke-free home...
The unit was purchased Brand New in November of 2017 from Crutchfield. It is in impeccable condition and comes with the all original packaging, accessories, and even the original receipt.
Paid $4,500 + Tax (Please Add 3.5% PayPal Fees to Total Cost)
Product Highlights:
Features:
200 watts per channel into 8 ohms (20-20,000 Hz) at <1% THD
400 watts per channel into 4 ohms (20-20,000 Hz) at <1% THD
550 watts per channel into 2 ohms (20-20,000 Hz) at <1% THD
2-ohm capability allows use with a wide range of speakers
signal-to-noise ratio: 120 dB
large precision-wound triple-shielded toroidal transformer with oversized filter capacitors for stable, noise-free operation
Advanced Load Monitoring (ALM) circuitry constantly monitors the amp's temperature, current, and voltage to ensure optimum long-term performance
ARC (Anthem Room Correction) speaker calibration kit (software, USB microphone, and telescopic stand with boom included)
ARC software requires a Windows-based PC
free ARC Mobile app allows you to run ARC from compatible iOS® devices
premium 32-bit/384kHz differential-output digital-to-analog converter
Connections:
digital audio inputs: 2 Toslink optical and 2 coaxial (supports PCM audio up to 24-bit/192kHz)
USB (Type B) input for connection to a computer (supports PCM audio sources up to 32-bit/384kHz, DSD 2.8 and 5.6 MHz
if using a Windows PC, a USB DAC driver must first be downloaded from Anthem's website and installed
AES/EBU digital audio input with balanced XLR connection
4 sets of unbalanced stereo RCA inputs
2 phono inputs for connecting a turntable (one for use with moving-magnet cartridges, one for moving-coil cartridges)
set of balanced stereo XLR inputs for connecting a compatible source
fixed-level stereo RCA preamp outputs for connecting a headphone amp or recording device
dual stereo RCA subwoofer outputs (selectable mono or stereo operation)
built-in bass management, in conjunction with ARC, is uniquely engineered for seamless subwoofer blending
custom-designed binding post speaker connectors
Ethernet port for Anthem Room Correction, software installation, and control
lets you operate the receiver from a web browser control screen on a PC connected to your home network
rear-panel USB Type A port (factory use only)
rear-panel USB mini B port for software installation and ARC via PC
RS-232 input, remote (IR) input and 12 volt-trigger output for use with external controllers
If connecting to a TV, please make sure you can select "PCM" output in its audio menu — the preamp's DAC cannot decode multichannel Dolby® Digital signals
General:
Remote Control
detachable power cable
engineered and crafted in Canada
17"W x 6-13/16"H x 17-9/16"D
weight: 40 lbs.
warranty: 5 years
Includes:
AC power cord
Remote control
2 "AAA" batteries
USB-B to USB-A cable
miniUSB-to-USB cable
3.5mm Microphone cable
USB microphone
Mic clip
Telescopic stand w/ boom
Ethernet cable
Operating Manual
