> Classifieds > > > SALE PENDING*** Triode TRX-M845 845/211 mono S.E.T. power amplifiers
SOLD - FOR SALE: SALE PENDING*** Triode TRX-M845 845/211 mono S.E.T. power amplifiers
Item #649454757
Info: SALE PENDING*** Triode TRX-M845 845/211 mono S.E.T. power amplifiers
USD $14999.00
Retail Price: USD $27500.00
Payment method: Cash, Paypal, Cheque, Money Order, Money Wire
Condition: 9 - Excellent (?)
Date Posted: Aug 10, 18 11:33am (PST)
Edited: Sep 26, 18 9:06am
About Seller: elem79
Freehold, NJ
[other classified ads]
Feedback Received: 11  See details
100% Positive Feedback
External Feedback: electrontube15 (113)
PayPal:
Days in System:47
Avg. Views/Day:20.38
***SALE PENDING***
For sale is a mint pair of Triode TRX-M845's. Pure class A Sonics!
These amps have low hours on them and sound stunning with either 211 or 845 tubes (user switchable).
They are true reference amplifiers and will not disappoint. I can tell you pictures to do not do them justice! The sheer size of them is truly impressive. Each chassis is over 100 lb.
The build quality is absolutely superb and is as good or better than the most expensive amplifier manufactures in high end audio.
They have more than enough power to drive most sanely built speakers out there with ease. These are true reference amplifiers and produce beautiful full class A sound with a sound stage you can walk through.
The only reason for the sale is because I don't have the time to enjoy them anymore.
Feel free to ask any questions you may have, and know that you are buying from a trusted Audiogon member with a long history of positive feedback.
The amplifiers have been in a dedicated listening room which is temperature and humidity controlled.
Comes with all the stock 845 and 211 tubes. Tubes have less than 300 hours on them. Tube cages included as well as all original packaging.
Amplifiers were Purchased from an authorized Triode Corporation of Japan dealer 1 year ago.
http://www.triode.co.jp/english/14.html
I will accept a bank check and will ship after it clears, Cash upon pick up accepted as well. Buyer pays PayPal fees and shipping. Will ship via Freight.
TECHNICAL DESCRIPTION:
The TRX-M845s are physically imposing mono block amps, each of which weighs over 100 pounds. The casework is gorgeous. The amps accept RCAs as well as XLRs. They will accept either 211 or 845 output tubes and in each instance, a switch makes the choice. Feedback is select-able via a rotary switch on the rear of each amp. Construction is by hand without printed circuit boards. Everything is hard-wired point to point in a very neat way. Components are chosen with great care, and include Koa resistors and Toichi capacitors. The tube sockets are nice ceramic and gold specimens that accommodate easy tube swaps,
being neither too tight nor loose. The circuit has three stages of gain using a 12AU7 and 6SN7 as the initial stage into an 845, which in turn drives paralleled 211/845 outputs producing either 40 watts with the 211’s or 50 watts with the 845’s. Put simply, this is one very special and unique pair of mono block amplifiers designed to maximize your musical enjoyment.
Shipping:
Flat rate of $500 or less depending on location. These will ship on a pallet in the original boxes via freight shipping.
Also available for local pickup/Demo in Central New Jersey.
Reviews:
http://www.audioreference.co.nz/node/3103/pdf
Reviwer comments:
The sound was simply spellbinding. I can't recall hearing imaging this good on any system using conventional speakers for less than US$100,000, and if you do the math, you'll note that this system doesn't even reach US$50,000. Not only did it image well in front of me, but it placed instruments three to four feet in front, behind, and beside the speakers! Bass control was tremendous, and the balance of warmth and detail throughout the midrange and top end was some of the best I've heard in a system where every component utilizes tubes. What's more, two of the products used in this system, the preamp and the amplifiers, just went into production less than a week ago, as they're the first of their kind for Triode.
Manufacturer Specifications:
TRX-M845 845 A class parallel single ended monaural power amplifier
Specification
Tubes : Output tube 845*2 or 211*2 , Driver 845*1 , Balance in 12AU7*1 , Pre 6SN7*1
Bias : Self bias
Output power : A class 50W at 8 ohms
Frequency response : 10Hz-50kHz(-2dB)
S/N ratio : 90dB
Total harmonic distortion : 0.1%
Input sensitivity : 0.9V
Input impedance : 100k ohm
Input terminals : RCA unbalanced*1 , XLR balanced*1(No.2 hot or No.3 hot switchable)
Output terminals : 4 ohms , 6 ohms , 8 ohms , 16 ohms
High quality banana plug capable type
NFB selector : 0dB , 3dB , 6dB
Equipped components : NEUTRIK XLR terminal (Germany)
Other functions : 845/211 bias selector
Bias check meter
Power consumption : 280W
Dimensions : W580mm*D440mm*H300mm
Weight : 58kg
Accessories : 211 tube*2 , Tube cover , AC cable
Includes:
All original accessories, tubes, cages, manual and boxes.
Similar items you might be interested in
# Caption Category Asking price Province Posted On Photo
1 Premium User FOR SALE or TRADE: 2 Amps: Matching vintage 1960's Electrohome Ultralinear mono block 7189 Vacuum Tube Amplifiers Tube Amplifiers $599.99 ON Dec 07, 2018
2 Dealer DEALER AD: FLUXION NT-6, 845 / 211 switchable SE monoblock power amplifier, 18 watts by 845 Tube Amplifiers $2500.00 ON Dec 05, 2018
3 Dealer DEALER AD: Quicksilver 8417 tube mono power amplifiers with EL34 output tubes - NEAR MINT !!! Tube Amplifiers $1595.00 ON Nov 23, 2018
4 Dealer DEALER AD: Quicksilver V4 tube mono power amplifiers - EXCELLENT (SOLD TO STUART) !!! Tube Amplifiers $4995.00 ON Nov 13, 2018
5 Premium User FOR SALE: Sophia Electric S.E.T. Music Baby Tube Amplifier - Hand Made in the US Tube Amplifiers $799.00 BC Aug 10, 2018
  • Last 48 hrs: 443
  • Active: 4504
  • Total: 664514
  • Last 48 hrs: 949
  • Total: 1364611
