> Classifieds > > > Space-Tech Lab. P-003 super low noise hum-free MC/MM phono stage with re-chargeable battery
DEALER AD: Space-Tech Lab. P-003 super low noise hum-free MC/MM phono stage with re-chargeable battery
Item #649450414
Info: Space-Tech Lab. P-003 super low noise hum-free MC/MM phono stage with re-chargeable battery
CAD $638.00
Retail Price: CAD $1280.00
Payment method: Cash, Paypal, Cheque, Money Order, Money Wire, Interac/EMT
Shipping weight: 5.00 (kg) Calculate Shipping
Shipping Dimension: 30.48cm x 30.48cm x 20.32cm
Condition: 11 - New (?)
Date Posted: Oct 19, 18 9:39am (PST)
Edited: Oct 19, 18 9:39am* Updated!
About Seller: Space-Tech Laboratory Ltd.
Space-Tech-Lab is a dealer or commercial user
New Westminster, BC
[other classified ads]
Product Brand: Space-Tech Lab.
Product Model: P-003
Feedback Received: 73  See details
100% Positive Feedback
Days in System:1
Avg. Views/Day:24.00
Space-Tech Laboratory - Super High-End Audio with affordable price
100% professional custom hand-made in CANADA
Visit www.TheBestAmp.com or www.Space-Tech-Lab.com for more details
EAT-100
New product introduction - EasyAudioTester Model: EAT-100 (A personal technician for everyone!! ) with discount -$100 now!!
Powerful tester with guided testing, super easy, quick and simple to use, for all non-technical audiophiles, DIYers, experienced technicians and engineers.
6-in-1 powerful tester which can test phono stage, pre-amp, power-amp, integrated amp, CD player, DAC or music server, EQ, crossover, speaker, cables as well as tube matching
Get our 10 free tips to improve your system performance without cost
Designer and manufacturer of over 100 models of super hi-end tube pre-amp and power amp, hybrid amp, integrated amp, DAC, Buffer amp, MC/MM phono amp, headphone amp, hi-end speaker systems and active tube crossovers. Hi-end TUBE pre-amplifier start from C$480 only, even our starting model can easily surpass the sonic performances of those selling US$3,000-4,000 with a big name , 30 days cash refund guaranteed minus re-stocking and shipping (see terms and conditions on our website )
7 day 12hr (9:00am-9:00pm) hot-line: (604) 254-8133
Flexible Showroom hours : Everyday possible between 10:00am - 8:00pm, by appointment only !! Please call / email to reserve a seat !
Item for sale : P-003 Hum-free high-gain wide-bandwidth precise MC/MM phono stage with re-chargeable battery, presettable MC gain and loading impedance.
Typically retail store / re-sellers on-sale for C$1,280 or higher!!
Our direct, from the factory price without wholesale + retail + marketing + reviewer markup :C$680 only!!
Take advantage of our newly built in-stock discount of only C$630!!
(free bonus 5V >> 12V adapter cable included for power up from 5V USB output, so that it will be possible to use any external 5V power bank to power up this unit, or charge the re-chargeable battery inside)
P-003-2 P-003-2
P-003-2P-003-2
MM/MC Phono pre-amplifier (hum-free) with re-chargeable battery & Presettable MC gain & load impedance
This is our newest state-of-the-art high gain low noise MC + MM phono stage. All components are meticulously selected and crafted in order to achieve the finest sound quality within the affordable price tag. This product offers superb resolution, very high gain and very low noise floor for even low output MC , at a super bang-for-buck price.
This phono stage provides both openness and a sweetness of character in a single unit. Offering a 40db MM gain and 40+26db(default x20) MC gain (user presettable gain from 1db to 30db possible)
This unit can also take MM cartridge from MC input, and boost the MM cartridge output level same as CD signal level (by setting the MC loading to 47Kohm, and MC gain to 3-4x ).
This unit built with heavy duty gold plated copper circuit board to ensure best signal transmission and minimal lost , with +/- 0.5db RIAA accuracy, -80db S/N for MM, and -70db S/N for MC input with 20x gain. This unit comes with very natural and smooth sound. Tonal quality and specification easily pair with thoes selling $3K-5K MC/MM solid-state phono stage in the industry.
MC gain and loading impedance presettable by plug-&-play resistors, you can also tweak the sound by using different type of resistors and values
MM input suitable for MM cartridge or high output MC cartridge from 10Kohm to 47Kohm loading impedance
MC input suitable for any MC or MM cartridge from 1 ohm to 100Kohm loading impedance
Built-in re-chargeable battery for AC off-line operation, 100% hum free even work with super low output MC cartridge, smart charger include in the circuit with auto stop when battery fully charged. The built-in re-chargeable is 3000mA lithium battery, which can let this unit run for many hours fully charged. This re-chargeable battery can easily be replaced with another one if it fails after many years of usage.
Even this unit comes with battery power, it can also run on AC power with included DC 12V 1A adapter. The power supply section is like an "always on-line UPS" system, power to signal circuit always re-generated by the battery power circuit to maintain the best stability and quality of sound.
 Separate "Charge" and "Power" switch, you can either listen during charging or without charger connected, or cutoff circuit power during chraging for faster charge cycle.
Norminal power draw around 400mAh
Specifications
No. of inputs 1 set of MM + 1 set of MC inputs
No. of outputs 1 set of RCA outputs
Freq response RIAA +/- 0.5db  from 20Hz - 20Khz , typical freq response 1Hz to 40Khz(-3db)
S/N > 80db MM , > 70db MC
Max. output volt 3Vrms
Phase non-inverted
manufacturing ultra heavy duty gold plated copper circuit board
user presettable x1 to x30 for MC stage gain , 1 ohm - 100Kohm for MC input loading
100% professional custom hand-made in Canada
Condition : New with 1 year free parts and labor warranty
Payment methods: Money order/ bank deposit / Email interac / cheque / PAYPAL (+4%)
Ship by : Canada Post , local pickup welcome
Shipping schedule : 2-3 business days
Satisfaction guarantee : 100% cash refund minus 5% re-stocking fee if return in 7 days (for local user), or 10% re-stocking in 15 days (exclude transit time) , no refund on S/H.
Images
