> Classifieds > > > Teac TN-400S turntable, 3 speed with Bordeaux Red plinth
FOR SALE: Teac TN-400S turntable, 3 speed with Bordeaux Red plinth
Item #649440541
Info: Teac TN-400S turntable, 3 speed with Bordeaux Red plinth
CAD $350.00
Retail Price: CAD $700.00
Payment method: Paypal, Interac/EMT
Shipping weight: 6.00 (kg) Calculate Shipping
Shipping Dimension: 42.00cm x 11.00cm x 36.00cm
Condition: 9 - Excellent (?)
Date Posted: Sep 19, 18 1:41pm (PST)
Edited: Oct 05, 18 10:45am
About Seller: Unity Audio
Nepean, ON
[other classified ads]
Product Brand: Teac
Product Model: TN-400s
Feedback Received: 10  See details
100% Positive Feedback
External Feedback: oz_enterprises (3048)
Days in System:35
Avg. Views/Day:6.71
Gently used with very few hours. Dust cover has some light marks on it.
Enjoy an espresso during a demo before you take it home.
Pickup in Barrhaven, or will deliver in the Ottawa area. I'm happy to set-it up and align it for you as well.
Willing to ship at actual cost of freight - counter weight and platter will be removed.
Info from the web:
Feature List
Three-Speed Turntable plays all the hits – both old and new
Aluminum Die-cast Platter and upgraded motor assembly provide years of service and stability
Newly designed, low-friction spindle reduces platter drag, resulting in enhanced speed consistency and tonal accuracy
Integrated USB Port for Digital Output allows PC Recording for easy archiving
Anti-skating Mechanism stays in the groove so you can stay in the groove
Static-balanced S-shape Tone-arm with Universal Head-shell for improved tracking
Built-in Phono EQ Amplifier and Switchable Phono/Line Outputs ensures easy setup with any Amp or Receiver
High-density MDF Chassis dampens vibrations and delivers rock solid performance
Detachable Dust Cover enables you to customize the experience to fit your own personal style
Upgraded Audio-Technica AT100E equivalent MM equivalent cartridge for accurate and detailed sound reproduction
TN-400S SPECIFICATIONS
Turntable section
Drive System Belt Drive
Motor DC Motor
Speed 33 1/3 RPM, 45 RPM, 78 RPM
Rotation Speed Variation +/–2%
Wow and Flutter 0.2%
Signal-to-Noise Ratio 67dB or higher (A-weighted, 20kHz LPF)
60dB or higher (unweighted, 20kHz LPF)
Platter Aluminum Die-cast
Diameter of Platter 12", 30cm
Tonearm section
Type Static Balanced, S-shaped
Effective Arm Length 8.8", 223mm
Stylus Pressure Range 0 to 5g
Supported Cartridge Weight 3.5 to 6.7g
13.5 to 16.5g (including head shell)
Anti-skating Adjustment Supported
Cartridge section
Type MM type (audio-technica AT100E factory installed)
Stylus Shape Joint-oval 0.3 x 0.7 mil
Stylus Construction Bonded Round Shank
Mount Half inch
Frequency Response 20Hz to 20kHz
Channel Separation 27dB at 1kHz
Output Balance 1.5dB
Needle Pressure 1.0 to 1.8g (approximate value 1.4g)
Vertical Tracking Angle 23 degrees
Supported Load Impedance 47k ohms
Output Voltage 4.5mV (1kHz, 5cm/sec.)
Cartridge Weight 6.5g
Replacement Stylus audio-technica AT100E
Phono Equalizer Amplifier
Type of Amplifier MM type (On/Thru switchable)
Analog Output
Connector RCA Pin jack (Gold-plated)
Output Voltage Phono/Line switchable
Phono Output 4.5mV (± 3dB)
Line Output 230mV (–13dBV)
USB Output section
Connector USB B type
Output Signal PCM 48kHz/16-bit
Supported OS Windows 7
Windows 8
Windows 8.1
Windows 10
OS X Lion (10.7)
OS X Mountain Lion (10.8)
OS X Mavericks (10.9)
OS X Yosemite (10.10)
OS X El Capitan (10.11)
macOS Sierra (10.12)
Power AC 100 to 240V, 50/60Hz
Power Consumption 1.5W (less than 0.5W at Standby)
Overall Dimensions
(W x H x D) 16.5" x 4.6" x 14.0"
420 x 117 x 356 mm
Weight Approx. 10.8 lbs. 4.9 kg
Accessories Felt Mat, EP Adapter, Counter Weight, Head-shell (audio-technica AT100E equivalent installed), Turntable(Platter), Dust Cover, Dust Cover Hinges, RCA Audio Cable with GND wiring, AC Adapter (GPE053A-V120050-Z), Owner’s Manual
Includes:
OBM, and all factory accessories.
  • Last 48 hrs: 362
  • Active: 4597
  • Total: 656789
  • Last 48 hrs: 757
  • Total: 1344645
