It is currently Tue Sep 25, 2018 8:54 am
Post new topic Reply to topic  [ 49 posts ]  Go to page 1, 2, 3, 4  Next
PostPosted: Mon Jul 04, 2005 4:39 pm
Hello,
When I changed the outlet in my apartment (an old building), I discovered the outlet has only live and neutral, no ground connection. As there is metal box surrounding it, I installed a connection between the outlet ground and the metal box. Ok, everything done, system reconnected and turned on, system sounds fine, a bit better than before since I used a higher quality outlet. Some ppl wrote to magazines saying they could hear the radio station thru the speakers even the amp is turned off, since the metal tube pipeline in the building acts as a giant antenna. But I didn't hear such artifacts. Am I doing the right thing? What are the requirements of electrical grounding in a building or house?
Any help appreciated,
Will.
 Post subject:
PostPosted: Mon Jul 04, 2005 7:49 pm
It is probably best to consult the Ontario Electrical Code for such requirements.....What you have experienced is older 2 conductor wiring which has not been upgraded however a 3-prong receptacle has been put in to replace all the outlets.....As far as a ground is concerned I believe it must be made through at least an 8-guage copper condutor to a cold water pipe just above where it enters the ground in basement or install a 10 foot copper grounding rod...A job for the electrician....
 Post subject:
PostPosted: Mon Jul 04, 2005 8:17 pm
Good advice - talk to your electrician to upgrade. The code changes quite frequently, and can be quite outdated after two years. Also, the language is sometimes without any knowledge not easy to understand. Believe me, I studied the code as it applies to low voltage (< 110V)
 Post subject:
PostPosted: Mon Jul 04, 2005 8:25 pm
Should have said consult the BC Electrical Code...
 Post subject:
PostPosted: Tue Jul 05, 2005 3:26 am
Our house is all 2 prong, and no metal conduit on the wiring either, so no luck grounding to that.
The only thing I worry about is that surge supressors won't work because they direct surges to the ground.
Did you check the outlet after you wired it? If not, get one of those testers at Canadian Tire with the LEDs. You may be surprised. If you grounded to the box, the building wiring is in a metal conduit, the box is attached to the conduit, and the conduit is grounded at the other end, you may have a ground!
And next time, get an electrician to do the work :D
 Post subject:
PostPosted: Tue Jul 05, 2005 4:58 am
I am definitley NOT an expert,,,,but I think you may be violating the electric code by grounding the outlet the way you have. I believe the only acceptable method is to a 3 conductor cable.
 Post subject:
PostPosted: Tue Jul 05, 2005 6:37 am
I would gestimate the wiring is atleast 45 years old or more.The only way to ground it properly is to run a ground wire adjacent to the wire feeding the outlet back to the fuse panel and connect it to the ground bus.I believe this is the only acceptable legal way of doing it.It's probably easier just to pull the old wire and replace it with new stuff.That in itself can be a nightmare if the old wire breaks while pulling the new.
Sorry I missed the part about all your outlets being grounded in a metal conduit.If this is the case you do indeed have ground as long as the metal conduit itself is grounded at some point.
 Post subject:
PostPosted: Tue Jul 05, 2005 12:05 pm
"Sorry I missed the part about all your outlets being grounded in a metal conduit.If this is the case you do indeed have ground as long as the metal conduit itself is grounded at some point"
Yes you MAY have a ground but not one that meets electrical code...For instance should you have a ground fault problem you will energize whatever metal is connected to the box creating a potentially dangerous situation..in other words someone could get hurt...or worse...The only acceptable ground is one made through a proper size conductor to the ground bus at the panel or to a cold water pipe or a ground rod...and yes do have an electrician do the work...[/quote]
 Post subject:
PostPosted: Tue Jul 05, 2005 1:01 pm
Read this, become a genius.
http://www.aes.org/sections/pnw/pnwrecaps/2005/whitlock/whitlock_pnw05.pdf
Always keep an edge on your knife, son
Cuz a good sharp edge
Is a man's best hedge
Against the vague uncertainies of life
Corb Lund
 Post subject:
PostPosted: Tue Jul 05, 2005 2:33 pm
Yaukui wrote:
That is a great document. I feel smarter already :D
 Post subject:
PostPosted: Tue Jul 05, 2005 2:56 pm
Yaukui wrote:
I second that "Great Document" but when do the smarts kick in ?
Louballoo
 Post subject:
PostPosted: Tue Jul 05, 2005 4:59 pm
If after reading this document you accidentally should connect your finger to the "hot" in your wall outlet.
 Post subject:
PostPosted: Tue Jul 05, 2005 6:25 pm
Shouldn't the OP resort to usin GFI recepticals? That way if something does go wrong the socket will trip.
 Post subject:
PostPosted: Wed Jul 06, 2005 5:10 am
Good read
 Post subject:
PostPosted: Mon Jul 11, 2005 7:42 am
sure is a good read. Put a sticky on it for everyone to read up on.
