By no means a new concept, but I do get a lot of blank expressions when I mention it to people as one of the best ways to set up a system that you can tweak to match your speakers to your room to your ears, without EQ.
If your haven't heard about it before, the concept is pretty simple, you have one stereo amp driving the highs and one stereo amp driving the lows. You need a pre-amp capable of dual outputs, one to each amp. Even some new home theatre amps will let you do this. And finally of course you need speakers that can be bi-amped. Your amps don't need to be matched to enjoy this and it is actually tweakers heaven to try different amps, solid state, tube, integrated or not, doesn't really matter as you have 3 volume controls to match things up.
Today I'm running the GF P-307 (Tube) as the pre-amp with the GF A-534 (300B tube) driving the lows and the GF A-330B (300B tube) driving the highs and the GF RBS-2 (2-way Vifa, 86dB) as the speakers. Don't forget to remove the single amp jumper bars from the speaker connectors.
I turn the amps to 3 o'clock and use the pre-amp to control overall volume, then adjust the individual amp's volume to tailor the sound to what I want, the RBS-2 soundstage best when pointed straight ahead (as do most speakers), but normally I find the top end a bit weak straight ahead, so normally I have them toed in for tonal balance. Now I can point them straight out and give the top end a boost (which I actually do by reducing the low end amp) then bump the up the pre-amp volume.
The difference between a single amp and the horizontal bi-amp is beyond beautiful. The amps perform better with a single speaker load. The speaker's crossover performs better not having to split the load. Again you sit there and go I want a tad more bass for instance and do a simple tweak and have it, you can change speaker positions (WAF for example) and compensate.
If you ever have a chance to hear a bi-amped system go for it and have fun, you may have a hard time listening to single amps again, no matter how good it is, you generally can't tweak it like you can a horizontal bi-amp system. And then there is tri and more horizontal amping
Ian
