It is currently Sun Jul 22, 2018 6:24 pm
PostPosted: Mon Nov 05, 2007 11:51 am
Best cd player under 500.00?
or is there one?
Thanks
 Post subject:
PostPosted: Mon Nov 05, 2007 12:01 pm
I always wonder in these threads what the word "best" really means.
I'm not allowed to have an opinion anymore.
Your Premier Canadian Oppo Dealer (http://solutionsav.ca/oppo.html). Please consider purchasing your Oppo from a CAM supporter. Thanks to all CAM members for your continued support! :)
 Post subject:
PostPosted: Mon Nov 05, 2007 12:36 pm
Maybe:
Best bang for the buck
Best sound
Best looks
Best features
Best options
etc...
Or maybe "best CDP that fits my needs?
Sorry king4276, hard to answer, depends on what you have, sound quality, features, new or used. I don't think there is an easy answer. Give us more info.
PostPosted: Mon Nov 05, 2007 12:38 pm
king4276 wrote:
...or is there one?
No there isn't. "Best" is a match to the amp and speakers in the system, and to your ears.
A village can't organize village life to suit the village idiot.
 Post subject:
PostPosted: Mon Nov 05, 2007 2:33 pm
I have a Sansui QRX 7001 amp and Bose 501's, I quess I'm looking for the best bang for my buck, sound is the main thing, When I say 500 or under that would be new or used.
I hope this helps.
Thanks
 Post subject:
PostPosted: Mon Nov 05, 2007 7:16 pm
New I would try the NADC525BEE,
 Post subject:
PostPosted: Mon Nov 05, 2007 7:27 pm
From what I've read and heard, an Oppo DVD player may be a good choice, if you want to spend the money on a CD player an Audio Refinement CD player would be a good choice, as is numerous Chinese brands that meet your budget.
Remember, information is not knowledge; knowledge is not wisdom; wisdom is not truth; truth is not beauty; beauty is not love; love is not music; music is the best.
-- Frank Zappa
Last edited by audiophile-4-life on Tue Nov 06, 2007 11:42 am, edited 1 time in total.
 Post subject:
PostPosted: Mon Nov 05, 2007 7:38 pm
I hope this helps.
Thanks
I am using a QRX-7001 in my office with a pair of JM Labs Daline 3.1 speakers. I am using a Sony DVP-NS775V SACD/DVD player I bought used for sixty bucks. Multichannel too! If you want to spend more, get a Cambridge 640C V.2
 Post subject:
PostPosted: Mon Nov 05, 2007 9:46 pm
Pioneer Elite DV46AV, plays it all at does it quite well, will be a good match to the rest of your system too. Priced at $399....
UNITY AUDIO
 Post subject:
PostPosted: Tue Nov 06, 2007 8:02 am
A best buy, may be a better approach, then you can include potential resale value if you come across another best in the future.
Ian
http://www.grantfidelity.com
 Post subject:
PostPosted: Tue Nov 06, 2007 8:30 am
Picked up one new landed from ebay for 200.00. (199.99 plus .01 frt US).
From Canada side nonetheless!!!!!
Your powers are useless........the monkeys are on my side.........
 Post subject:
PostPosted: Tue Nov 06, 2007 1:47 pm
The best CD player for under $500 is the one you get at a garage sale for $10, only to find out that it works perfectly and came with the romote and manual!
 Post subject:
PostPosted: Tue Nov 06, 2007 3:58 pm
Good answer - welcome to CAM! :D
UNITY AUDIO
 Post subject:
PostPosted: Tue Nov 06, 2007 8:03 pm
A used Arcam would be a good choice.....say a CD72 or CD73......
 Post subject:
PostPosted: Tue Nov 06, 2007 11:41 pm
My best yet is a Dan Santoni modded Toshiba SD3950.
Have been playing it with my maggies and some time with my heresey's.
Just too much time on my hands.
A big nod to Dan at DTS!!!!!!!!!
