It is currently Mon Sep 24, 2018 4:06 am
 Post subject: Pre-DAC? Source Switcher
PostPosted: Sun Aug 19, 2018 11:31 am
I have an Auralic ARK MX+ DAC that I really like, but it only accepts one source at a time.
I'd like to be able to use my DAC with multiple sources without having to manually swap cables in the back of the unit. Is there a device for such a thing?
Thanks in advance.
PostPosted: Sun Aug 19, 2018 1:47 pm
There are switchers for Toslink/SPDIF.... if you are using optical outputs to the DAC optical input, Or Coax, than you could get a optical, Coax switcher...
I use one in the family room, Playstations, Xboxes, Blueray, Streamer....needed 6 in all and the processor did not have enough room.
PostPosted: Sun Aug 19, 2018 2:07 pm
Not that hard to find...
https://www.amazon.ca/Splitter-Aluminum-Material-Dolby-AC3-Converter/dp/B0791CNDHW/ref=sr_1_6?ie=UTF8&qid=1534716372&sr=8-6&keywords=toslink+switcher
https://www.amazon.ca/TNP-Toslink-Digital-Optical-Control/dp/B01HO0TITC/ref=sr_1_9?ie=UTF8&qid=1534716372&sr=8-9&keywords=toslink+switcher
https://www.cs1.net/products/audio_authority/1177A-1-.htm
www.leohl.ca
PostPosted: Sun Aug 19, 2018 2:39 pm
What are your source outputs? AES, toslink/optical, bnc, spdif, USB?
PostPosted: Sun Aug 19, 2018 2:49 pm
Sorry I thought that you had an optical in, my first 2 links are useless.
Looks like you have USB and Coax inputs only...
www.leohl.ca
PostPosted: Sun Aug 19, 2018 2:59 pm
with those inputs then you need a dac that outputs coax. It essentially passes the signal and operates as a hub.
PostPosted: Sun Aug 19, 2018 3:03 pm
I think they want a Pre-DAC? Source Switcher...
www.leohl.ca
PostPosted: Wed Aug 22, 2018 4:00 am
Exactly. Thanks for the suggestion. It's not exactly what I need since I use the USB input as well, but it's closer to what I'm looking for.
PostPosted: Wed Aug 22, 2018 5:22 am
How about a Dac with multiple inputs?
PostPosted: Fri Aug 24, 2018 6:31 pm
But I like my Auralic so :(
PostPosted: Sat Aug 25, 2018 5:29 am
I owned this unit for a time. it would provide what you are looking for as an input selector, via remote even, and then pass the signal via coax or tossing to your Auralic.
http://www.essenceelectrostatic.com/product/hdacc/
PostPosted: Sat Aug 25, 2018 7:33 am
Some thing like these with the correct rca to bnc or rca to f connector will do it while preserving the impedance and isolation needed .
https://www.ebay.com/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=BNC+Manual+Switch+BOX&_sacat=0
https://www.ebay.com/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=Switch+Coaxial+RF+abc&_sacat=0&LH_TitleDesc=0&_osacat=0&_odkw=Switch+Coaxial+RF&LH_TitleDesc=0
Add remote to the search terms and get more results .
PostPosted: Sat Aug 25, 2018 7:39 am
these appear to be for video
PostPosted: Sat Aug 25, 2018 7:50 am
mpublicover wrote
[/quote]
these appear to be for video[/quote]
Yes they are .They will switch digital audio without issue . I have done it until I could find a more elegant solution
