It is currently Thu Sep 20, 2018 11:11 am
PostPosted: Sat Aug 18, 2018 4:54 pm
Hi all,
As the title states, I would like to consult with the many knowledgeables folks here on possible tonearm choices for my Garrard 301 rebuild. To put into perspective, I want to aim for a high end low output moving coil cartridge and want to know what tonearms would be most suitable for my application. I may post pics later of the massive solid wood plinth which I believe can house longer tonearms as well. Anyhow, these are questions:
1) Any 9” tonearm recommendations under $2000?
Is the Infinity Black Widow a suitable choice or are there any low mass high compliance cartridge recommendations to match? How about the Oracle Prelude arm taken from an Alexandria?
2) 10”-12” tonearm recommendations under $3000?
Is the Pro Ject 10cc a suitable choice on the Garrard? My dealer has one but I’ve never read of anyone using Pro Ject tonearms on a Garrard 301.
3) If none of the choices above are recommended, what are current users of Garrard 301’s using of one has a low outpute moving coil cartridge? I keep reading about Fidelity Research, Ortofon RMG, Rega RB300/Origin Live, Kuzma, plus some other high end stuff.
PostPosted: Sat Aug 18, 2018 5:08 pm
Please PM me regarding tonearms
PostPosted: Sat Aug 18, 2018 6:21 pm
for n.1....sme 3009 but also the 309 may be good but probably $$$
for n.2.... no, to the Project arm but again the sme 3012 or sme 312 if budget allowes...
I like the old Ortofon tonearms the best (RMG, RMA or RF) or vey good was FR 64s on it too....other used also Rega with modern cartridges.
PostPosted: Sat Aug 18, 2018 6:49 pm
3. I like the EMT 997 with TSD15 on my 301. I'll post a picture if I can find it.
I'll also add:
1. Ortofn RMG 212 or SMG 212
2. Ortofon RMG 309, SME 3012
I used them all mainly with Ortofon SPU and Denon 103R and I like them all.
Here is a picture of mine:
PostPosted: Sat Aug 18, 2018 7:52 pm
Agreed with both. Add the Linn ittok for the 9" arm. And perhaps the Ekos but that may be over budget
PostPosted: Sat Aug 18, 2018 8:33 pm
Depends what sort of cartridges you want to use. The Ortofon arms are heavy and ideal for the Ortofon SPU's. If you go with a light 70's arm like the Infinity, it puts you into compliant MM's like the Shures and Supexes were in the day.
If it were me I'd go medium-heavy on a 301. A used FR/Ikeda, Graham, or maybe the newer Jelco or Abis if you don't want second hand.
PostPosted: Sat Aug 18, 2018 8:37 pm
I would suggest a Jelco 750 or if you can find one, a Fidelity Research FR64S or even an FR12 -not easy to find. Otherwise, a SME 5000 would be another that comes to mind.
PostPosted: Sun Aug 19, 2018 4:50 am
it's critical to match the tonearm with the cartridge, regardless of the table. the table type, belt, idler, direct, has little to no bearing on the arm/cart.
you have to decide on a budget for arm/cart combination.
the plinth may limit the length of the arm. if it's not designed to take a 12" arm, then you're limited to 9 or 10 inch arms. however, the kuzma arms would be an option. with the VTA tower, a 12" arm mounts on a 10" platform.
http://www.corbysaudio.com
info@corbyframing.ca
toll free 1-877-689-1976
local 905-689-1976
Kuzma, Clearaudio, Rega, Music Hall, Charisma, Haniwa, Audiodesk, Acoustic Signature, Reed, Cardas, Dynavector, Benz micro, Harmonix, Allnic, Ortofon
BBIC
Users browsing this forum: Google [Bot] and 3 guests
