It is currently Tue Sep 25, 2018 9:38 am
 Post subject: CLASSE DR4 ???
PostPosted: Wed Aug 15, 2018 1:35 pm
I have a Classe DR4 Preamp and love it.
BUT
There is no on and off switch and according to the manual it's fine to leave it on all the time but it drives me nuts so I'm always un-plugging the power cord.
My concern is that over time this will wear out or damage the power cable input.
Can anyone recommend some kind of power switch box or any other kind of solution (Don't want to use another power bar)?
Thanx. KB
 Post subject: Re: CLASSE DR4 ???
PostPosted: Wed Aug 15, 2018 1:56 pm
leave it on...it will deliver peak performance
PostPosted: Wed Aug 15, 2018 2:05 pm
Power switch where the fuse is then internal fuse holder.
G
PostPosted: Wed Aug 15, 2018 3:21 pm
BUT
Thanx. KB
Why does it drive you nuts?
PostPosted: Wed Aug 15, 2018 4:24 pm
i have a krell pre amp. wich is also like that .in the case of the krell it is class A. it is because those pre amp will sound better when warm. it is said to consume only 15 watt, the company recommended to keep it on.
I unplug it only if I know I am not going to use it for a while. but that dosen t happen often.
PostPosted: Wed Aug 15, 2018 4:36 pm
+1
PostPosted: Wed Aug 15, 2018 5:33 pm
Dave Reich didn't forget to design it with a power switch. Leave it on. There's a useful mute switch instead.
My DR7 has a power switch on the back of the power supply chassis, but not on the preamp chassis itself.
PostPosted: Wed Aug 15, 2018 6:27 pm
If you are worried about power consumption, either for cost or environmental reasons, ask Classe what the standby power consumption is and then work out the cost per year or the draw on the electrical system.
This could be easily figured out...my guess is 24 hours of standby takes less energy/cost than making a cup of coffee on a Nespresso machine.
Happy listening
PostPosted: Wed Aug 15, 2018 7:22 pm
Tom_r wrote:
+1
Agreed
PostPosted: Thu Aug 16, 2018 12:38 am
I’ve had a Classe DR2 and for the 7 year, it stil on and never had a disfonction. There Was an on/off switch on it but I never use it...except When I sold it or change the system place... you don’t have to wait till it is hot to have his full potential.if I remember well, it was written to keep it on...but i’m not sure...
PostPosted: Thu Aug 16, 2018 2:46 am
The amps are a different story. The mute button on the pre will protect the amp/speakers, but the amp has no such device (or other protection ftm). Also, DR2/3 amps were biased in total class A so unlike the pre, leaving them on will cause lots of excess heat and electricity consumption. The extreme heat also affected the life span of some of the internal components (I do leave my DR3 on almost all the time though).
PostPosted: Thu Aug 16, 2018 4:37 am
As asked earlier, what is driving you nuts?
I always find it best to refer to the manual as you did.
https://www.hifiengine.com/manual_library/classe-audio/dr-4.shtml
Page - 5.
Power consumption is minimal, and to leave it on, this is why there is no on/off switch.
www.leohl.ca
PostPosted: Thu Aug 16, 2018 5:49 am
BUT
Thanx. KB
Your best option is to leave it on, but, if it really bothers you that much, plug it into something with an off switch.
Got Hi-Fi?
PostPosted: Thu Aug 16, 2018 6:59 am
Do you unplug your fridge when you leave the house? Or your alarm clock?
It's meant to be left on.
Power cycling is hard on equipment.
I've got a phono section that's been left on for at least a couple years now....
PostPosted: Thu Aug 16, 2018 8:28 am
Speculating but no preamp power switch insures no power up/down thumps should you forget the sequence.
G
