It is currently Fri Aug 17, 2018 1:36 am
 Post subject: repair stripped screw
PostPosted: Fri Jul 20, 2018 12:10 pm
I have a stripped tiny hex screw preventing me from popping the lid of one of my components.
I've tried a screw extractor from Canadian Tire which didn't work. Does anyone know where or how to fix this?
PostPosted: Fri Jul 20, 2018 12:23 pm
a pics will help us to help you :-)
PostPosted: Fri Jul 20, 2018 12:24 pm
Drill it out would be your best bet I would think or take it to a machine shop, post a pic if you can.
PostPosted: Fri Jul 20, 2018 12:38 pm
Extractor should work. Try hammering it in lightly to get it to bite. Better yet find a different hex bit. Tolerances on hex bits are all over the place. Some are noticeably larger than others in the same nominal size.
PostPosted: Fri Jul 20, 2018 12:41 pm
PostPosted: Fri Jul 20, 2018 12:43 pm
I have been successful with a star bit, tilting it hoping to catch an edge
PostPosted: Fri Jul 20, 2018 12:46 pm
if you can't wedge a square driver (Robertson) or allen key or something in the hole of the screw to remove it next step is use a small diamond point chisel to tap into the outside head of the screw head, at about a 30 deg angle and using a small hammer tap the screw loose
PostPosted: Fri Jul 20, 2018 12:47 pm
I have in the past used a drop of high shear strength 2 part epoxy on the end of a disposable but close fitting allen key. Be careful not to overflow the head of the screw, once set you should be able to apply enough force to remove the screw
PostPosted: Fri Jul 20, 2018 12:48 pm
use a Robertson bit that bottoms in the bore, it will work.
PostPosted: Fri Jul 20, 2018 12:52 pm
5 Ways to Remove Stripped Screws
https://www.youtube.com/watch?v=gt1vTfGJNp4
-- 20 Jul 2018 15:57 --
Also apply liquid wrench and wait for 15 minutes.
PostPosted: Fri Jul 20, 2018 12:58 pm
lol...thanks for all the feedback
problem is that it is a tiny and countersunk screw
I'm going to try a few of the suggestions and hopefully leave the component and my fingers undamaged
PostPosted: Fri Jul 20, 2018 12:59 pm
If nothing else works.... really small cutting disc on a Dremel, hold it sideways to cut a flat groove in the screw head,
Then use a flat screw driver.
Be careful with cutting, start small and a small cut is enough.
Try it first on a spare screw.
PostPosted: Fri Jul 20, 2018 1:01 pm
A simple trick to loosen screws and set the drive bit. select the correct bit size, insert it into the fastener, then smartly whack! the driver. This will shock the threads of the fastener, set the bit deeper into the fastener head, and make the less likely to strip. All this is wasted on where you are right now....try and find a drive bit that most closely matches the screw head. Try the whacking trick.
WARNING... If you are not sure that the screw you are attempting to remove holds circuit boards or other sensitive components do not bang the screws. Otherwise this trick has worked well for me for many years.
Good luck
PostPosted: Fri Jul 20, 2018 1:34 pm
Good luck
As my old Philipino friend would say-
Wake it up!
PostPosted: Fri Jul 20, 2018 1:46 pm
https://store.snapon.com/Combination-Ex ... 30634.aspx
Users browsing this forum: cleopatra52 and 16 guests
