It is currently Wed Jul 18, 2018 2:30 pm
PostPosted: Wed Jul 11, 2018 9:26 pm
I recently purchased a Nad 3020 integrated amp.
It is the previous model with the usb port and a power cable with a female c-5 end.
I was thinking of upgrading the power cord with an AudioQuest NRG-X3 Power Cable (C5).(approx $100)
It seems they are hard to find if not discontinued.
Any suggestions as to a replacement or where to find one.
Thanks in advance.
Greg
PostPosted: Thu Jul 12, 2018 1:23 am
Hi Greg
I sent you a PM. They have been disco'd but some retailers still have some. -Jody
PostPosted: Thu Jul 12, 2018 4:13 am
Did the NAD 3020 not come with an encapsulated power cable?
The connector in question C5 may have been added at a later time.
You may be able to purchase an adapter.
https://www.ebay.com/itm/IEC-Male-Kettle-C14-to-Clover-Leaf-Female-C5-Power-Adapter-10A-Plug-Socket-/332331924501
or
Replace it with a C14 connector.
https://www.dhgate.com/product/iec-320-c14-male-plug-inlet-panel-socket/237069085.html
www.leohl.ca
PostPosted: Thu Jul 12, 2018 4:33 am
The attachment NAD3020.JPG is no longer available
or
Think he is referring to the D 3020.
PostPosted: Thu Jul 12, 2018 4:36 am
or
It is amazing how one letter in a part number can make a huge difference, could still use the adapter...
(I missed the USB port part)
NAD 3020 Integrated Amp vs NAD D3020 Hybrid Digital Amplifier
www.leohl.ca
PostPosted: Thu Jul 12, 2018 6:55 am
Hi
Yes I should have been clearer.
It is........NAD D3020 Hybrid Digital Amplifier.
I believe I have found what I need thanks to CAM.
Greg
-- 12 Jul 2018 16:01 --
Thank you Ohms as the adapter is available for $20 on amazon canada.
I never thought of that.
Great idea.
Users browsing this forum: Google [Bot] and 3 guests
