It is currently Tue Sep 25, 2018 1:49 am
Only paying dealers and advertisers may post here. Please only post using your MAIN official dealer account, other posts will be deleted without warning.
The only replies allowed by non-dealers in this Dealer News & Announcements Forum should be directly related to what is being announced (availability, timeline, pricing, etc..) and not on the merits of the products themselves. This is not a forum for review or debate of the merits of various technologies and products being announced.
Post new topic Reply to topic  [ 1 post ]
PostPosted: Sat Jul 07, 2018 9:09 am
We've stocked a few of the key cables to allow our clients to take them home and try them out in your own systems.
Give us a call to arrange a demo.
Key features of the ZL cables:
Barrier free conductors
Traditional soldered or clamped connections between terminations and conductor create two resistant barriers (solder has much greater resistance than copper or silver). Our direct, high temperature melt welding (1000o C), without solder, removes two obstacles in the signal path by melting terminations and wire conductors into a single, seamless material.
Permanent contact pressure via heat-treated beryllium-copper terminations
Contact resistance is a critical factor for signal transmission. Higher contact pressure and a larger contact surface mean less contact resistance and better signal transfer. Traditional bronze, pure copper and phosphorous-copper terminations cannot provide sufficiently secure and long-lasting contact pressure. Our precision-milled, slit, heat-treated beryllium-copper terminations provide maximum contact surface and powerful contact pressure for minimal signal loss – for life.
Mu-metal shielding for true protection from EMI
While all other audio cable manufacturers use copper and/or silver shields for signal cables, Allnic uses ‘Mu-metal’ as braided shield for its interconnect and digital cables (RCA & XLR) – a world-premiere in the audio industry.
Traditional copper and/or silver mesh shields provide effective protection against electrically generated noise, but they are ineffective against magnetically induced noise. This is because magnetically generated interference freely penetrates both copper and silver. Only Mu-metal (a nickel alloy material) can protect the audio signal from both electronically and magnetically induced noise. Test data show that Mu-metal shielding reduces electromagnetic noise to less than 1/30th of what braided copper shield allows, down -30dB in comparison.
No more loosened binding posts
With our patented double-bladed speaker terminations, there is no need to go behind your loud speakers every month to re-tighten binding posts. Our unique double-bladed spade terminations minimize contact resistance and will not loosen, even when subjected to severe speaker vibration: no need to re-tighten binding posts for years.
Mid-Range Control Technology – MRCT®
Allnic considers an exaggerated midrange to be a clear indicator of inaccurate signal transfer through a cable, and the most formidable distortion to overcome in cable design. Allnic’s MRCT is the result of meticulous listening and measurements to select carefully formulated metal plating for slight midrange “braking” and heavier wire gauges for accurate low frequencies, as well as to ensure control of capacitance for provision of stunningly realistic high frequencies.
http://hammertoneaudio.com/zl-technology
http://www.corbysaudio.com
info@corbyframing.ca
toll free 1-877-689-1976
local 905-689-1976
Kuzma, Clearaudio, Rega, Music Hall, Charisma, Haniwa, Audiodesk, Acoustic Signature, Reed, Cardas, Dynavector, Benz micro, Harmonix, Allnic, Ortofon
BBIC
