It is currently Tue Jul 17, 2018 2:00 am
PostPosted: Sun Jun 24, 2018 10:00 am
Hi guys, I am recapping a couple of guitar amplifiers and I need 8 LCR 50/50/500 filter can capacitors… I know these aren’t made anymore so it’s been tough to find them, if anybody has a lead on some, I would really appreciate it,
hope you are all having a great weekend,
KEITH
PostPosted: Sun Jun 24, 2018 10:01 am
KEITH
PostPosted: Sun Jun 24, 2018 10:38 am
KEITH
As far as I know you can use either one of these Caps as replacements.
https://www.thetubestore.com/f-t-can-ca ... -50uf-500v
https://www.thetubestore.com/jj-can-cap ... x-50f-500v
PostPosted: Sun Jun 24, 2018 11:04 am
KEITH
Thank you Joseph, I appreciate it… But these don’t sound quite the same as the LCR caps…
PostPosted: Sun Jun 24, 2018 12:16 pm
Try ars caps
PostPosted: Sun Jun 24, 2018 4:55 pm
they are still around....
found some in seconds, you should be able to find some closer to you...
https://www.justradios.com/DUALsection.html
ok, and also in other places:
https://www.partsconnexion.com/JJCAP-64126.html
You have to use clamps, so you need to make a few chassis holes to screw mount the clamps, and that's it. Maybe enlarge the holes in the chassis to clear the pins of the new caps (where the pins usually come through into the bottom, where the wiring is).
$88 cdn plus tax and shipping, probably $2 each for the 8 clamps, from the same source.
'the tube store' has some as well.
I think you can still get new cans in exactly the original plain aluminum can style, with the twist in pins instead of clamps.
PostPosted: Sun Jun 24, 2018 6:49 pm
BinkyTheCat wrote:
Try ars caps
Really... Thanks Binky! Those things are really cheap too, you are the second person that’s told me to try these… So, in your opinion, they are all a lot more like the LCR Than the other new production stuff?
PostPosted: Mon Jun 25, 2018 1:36 am
I might have some nos.
PostPosted: Mon Jun 25, 2018 5:14 am
That would be fantastic brother… i’d really appreciate it,
Even four of these would get me started with one of my amplifiers
:D
PostPosted: Mon Jun 25, 2018 5:26 am
Thank you Ken,
yes I also found those in seconds…
I am looking for LCR, which sound better/smoother in my guitar amplifiers…
PostPosted: Fri Jun 29, 2018 6:01 pm
Thanks to the guys that have provided me with four of these, I could use four more… If Anybody has some they want to sell, or knows where there are some more, hit me up, I’ll pay! :D
PostPosted: Wed Jul 11, 2018 8:47 pm
Need 4 more :mrgreen:
PostPosted: Fri Jul 13, 2018 12:32 pm
BinkyTheCat wrote:
Try ars caps
Maybe I’m going crazy Binky, but I can’t find any website with these ARS caps for sale… The only place I found them was on eBay and that auction has ended…
PostPosted: Fri Jul 13, 2018 1:04 pm
http://www.arselectronics.com/ARSWEB/CapPage2.html#dual
PostPosted: Sat Jul 14, 2018 11:43 am
Direct... Duhhhh! why didn’t I think of that...
