It is currently Thu Jul 19, 2018 2:01 am
PostPosted: Tue Jun 19, 2018 12:18 pm
I need 4 bulbs for a SAE Mark ivcm amp, I can not read the number on the bulbs. Any help, and can someone on here supply them or let me know where to get them? Thanks
PostPosted: Tue Jun 19, 2018 12:36 pm
not sure if they're the same but I recently had my Mark 2500 tuned up, the old bulbs in it were GE 47
PostPosted: Tue Jun 19, 2018 3:39 pm
If they are not GE 47, post a picture of what you have.
www.leohl.ca
PostPosted: Tue Jun 19, 2018 4:17 pm
Posting a photo of bulbs might help. Or check service manual / schematic and post the type/voltage/current characteristics. If they're regular Type 47 bulbs, you can buy them everywhere - last time I bought a whole box from Grainger.
Or you can contact Dave at www.dgwojo.com - he sells bulbs for everything.
PostPosted: Wed Jun 20, 2018 3:12 am
Thanks the bulb does say 47 but looks like it may be C M 47 are these the same as G E 47
PostPosted: Wed Jun 20, 2018 6:42 am
Yup.
I'm assuming for the meter lamps.
#44 bulb will be brighter if that helps.
G
PostPosted: Wed Jun 20, 2018 7:29 am
http://www.wjoe.com/
they have everything vintage
PostPosted: Wed Jun 20, 2018 8:54 am
Thanks I picked up 4 47's,, wish I knew about the 44's being brighter.
-- 20 Jun 2018 16:55 --
Can I use silicone to secure the new bulbs? Or should I use window type putty? thanks
PostPosted: Wed Jun 20, 2018 9:30 am
be careful when going brighter as xtra bulb heat could be an issue with plastics.
another option is an led bulb.
either google type 44 led or (think base is a...) ba9s led in required voltage. then you get color options!
PostPosted: Wed Jun 20, 2018 9:40 am
Why?
PostPosted: Wed Jun 20, 2018 10:06 am
Should look something like this.No?
G
PostPosted: Wed Jun 20, 2018 11:21 am
My lights sit in a small channel held in with what looks like dried white caulking I will take a picture when I change them........
Users browsing this forum: fifthbusiness, postmen and 10 guests
