It is currently Sun Sep 23, 2018 8:02 am
PostPosted: Wed May 23, 2018 1:46 pm
Hey all, I fried a woofer in one of my TimeFrame speakers. Were they made by Philips, it says made in Japan?
I just want to know if I can still get a replacement off the shelf somewhere.
PostPosted: Wed May 23, 2018 2:01 pm
Welcome to CAM, I was born in Niagara Falls :D
Is it in need of a re-foam (maybe rubber surrounds?), or is the coil shot, maybe the crossover?
Is there a part number on the woofer? (DCM 160Fw126L).
2011. Lloyd Naftolin
http://www.canuckaudiomart.com/forum/viewtopic.php?t=19462
2013.
http://audiokarma.org/forums/index.php?threads/dcm-tf250-woofer-replacement.519265/
You could contact The Speaker Exchange.
https://reconingspeakers.com/
www.leohl.ca
PostPosted: Wed May 23, 2018 2:55 pm
viewtopic.php?f=6&t=50291
Were my comments so bad you had to create another account?
PostPosted: Thu May 24, 2018 2:40 pm
I think 2 accounts is a nono.
What are the odds that 2 people from Niagara Falls are looking for the same woofers, from the same speakers, with the same issue.
But this one was started first...
www.leohl.ca
PostPosted: Thu May 24, 2018 3:14 pm
Maybe the OP just likes the Song... "Take Me Out to the Ballgame" (but, I sincerely doubt it).
... For it's one, two, three strikes, you're out
At the old ball game
PostPosted: Sat May 26, 2018 3:56 am
yes...one coil is rubbing
yes...160Fw126L
thanks
Dawico
PostPosted: Sat May 26, 2018 5:04 am
No they do not.
Find a pair...
Replace the pair...
Watch replacement depth
PostPosted: Sat May 26, 2018 8:33 am
Can my wife not "play ball" at CAM too?
-- 26 May 2018 16:38 --
BinkyTheCat wrote:
No they do not.
Find a pair...
Replace the pair...
If I replace the bad one with an original there is no need to buy two...wasted $$$
It will be a factory match and no need to measure
PostPosted: Sat May 26, 2018 8:41 am
If you say so.
Seem to have it under control.. .
PostPosted: Sat May 26, 2018 8:43 am
2013.
yes the coil is ruined and your part # is correct
Thanks
Dawico
Users browsing this forum: allhifi, blakcloud, bolly, DHMC2000, Google Adsense [Bot], meiwan and 6 guests
