It is currently Fri Aug 17, 2018 1:12 pm
PostPosted: Mon May 21, 2018 1:07 pm
Hi all.
Just noticed on of my Pro-Ac Studio 150 tweeter cones is pushed in and wrinkled ?
Does not appear to be torn at all.
How can I fix this easily myself ( if possible ) , or should I take it somewhere ?
Thanks
Wayne
PostPosted: Mon May 21, 2018 1:14 pm
Maybe use a vacum?
PostPosted: Mon May 21, 2018 1:15 pm
It is just a dustcap for the voice coil. It won't effect the sound being like that . But if you use a bit of tape you could get most of it out.Just carefully touch the dented part with the sticky side of the tape and gently pull it out.
PostPosted: Mon May 21, 2018 1:18 pm
Bubble gum can work (chew it good 'till sticky).
I've been there in the past ... used to have my main speakers in the living room with the kids ... now have a dedicated room which helps a lot!
-- 21 May 2018 17:21 --
I do question that ... the tweeter dome is usually designed for correct timing, caved in it actually sits farther back. Whether or not it is actually audible, I can't say ... but it is a speaker diaphragm, not just a dust cap, otherwise, you could just cut it out and throw it away ...
PostPosted: Mon May 21, 2018 1:24 pm
If you can hear a difference with it dented or not, you have better ears than anyone I have ever dealt with.
PostPosted: Mon May 21, 2018 1:31 pm
If your handy pull tweet, pull diaphragm and push dome from inside.
I like doin it the hard way : )
PostPosted: Mon May 21, 2018 1:34 pm
Get a toilet paper roll core or paper towel roll core, place it over the dome and suck it out.
A vacuum cleaner will work too but the suction might be too high and you could risk making things worse, breath suction is about right.
Good luck
PostPosted: Mon May 21, 2018 1:41 pm
might affect the sound off axis you should be able to get most that out with a small piece of duct tape been there done it
PostPosted: Mon May 21, 2018 1:46 pm
Good luck
I was thinking, maybe a drinking straw would work?.
PostPosted: Mon May 21, 2018 1:56 pm
Good luck
Thanks so much , used a toilet paper core and worked great.
Thank you.
PostPosted: Mon May 21, 2018 3:00 pm
painters tape can also work quite well. Use a fingernail to gently rub it on to the dome surface, and then pull the tape off at an oblique angle. Slowly.
PostPosted: Mon May 21, 2018 3:06 pm
Good luck
Thank you.
Wonderful! Good job.
PostPosted: Mon May 21, 2018 3:32 pm
what really happened
PostPosted: Mon May 21, 2018 5:12 pm
not even a hint of a wrinkle. purdy gud eh?
PostPosted: Mon May 21, 2018 6:21 pm
Good luck
Thank you.
I am glad it worked out! :D
Matt
