It is currently Fri Jun 22, 2018 2:58 am
PostPosted: Sat May 19, 2018 3:10 pm
I can honestly say my tweeters are dead silent. You can put your ears right up to the tweeter with my amp or receiver on and not a peep. Have to say thanks to Furman for that.
PostPosted: Sat May 19, 2018 3:41 pm
And?...... ??
PostPosted: Sat May 19, 2018 4:51 pm
it could also mean that your speaker are low sensetivety, or you have blown tweeter :lol:
PostPosted: Sat May 19, 2018 5:30 pm
I got a cat that's dead quiet until I shake his urn.
PostPosted: Sat May 19, 2018 6:21 pm
93db, and tweeters just fine
-- Sun May 20, 2018 8:22 am --
brownslane wrote:
And?...... ??
Just saying!!!.
-- Sun May 20, 2018 8:23 am --
Mine is in a shoe box out back under a big rock.
PostPosted: Sat May 19, 2018 7:12 pm
inaudible from where I sit so I'm not worrying about it. I dont dare even put my ear close to the compression tweeter to find out LOL
PostPosted: Sun May 20, 2018 2:17 am
What amp do you use? And what Furman product?
This is me: http://www.canuckaudiomart.com/view_userimages.php?user_id=97484
PostPosted: Sun May 20, 2018 3:23 am
Nasty, but funny...
PostPosted: Sun May 20, 2018 4:59 am
I use a combination of a Furman SPR 20i Voltage regulator and Reference IT 15i power conditioner with balance power on 2 outlets. Always been a firm believer in supplying my gear with the best power possible. We know how polluted out power lines are coming to our properties, and why make the components of our gear work harder. In the 30+ years I've been into home audio and home theater I have never had a piece of equipment die on me or go faulty. As for my audio, I use a combination of a Anthem MCA 20 and Yamaha 3050.
-- Sun May 20, 2018 7:01 pm --
I felt the same was myself. Then I started to think, if noise is coming from the tweeter that shouldn't be it has to be having an effect on what it produces when it does. Better to have the tweeter dead silent so when it has to do its job all its doing is its job.
PostPosted: Sun May 20, 2018 5:29 am
Hiss is usually a product of self noise inherent in component/circuit topology.
Johnson,thermal,1/f,shot etc...low noise transistors,low impedance circuits,board layout.
Clean power doesn't hurt either.
PostPosted: Sun May 20, 2018 6:07 am
It's all a out your amp noise.
My tweeter have 96 db efficienty and i hear it.
My amp is just not dead silent enough.
PostPosted: Sun May 20, 2018 6:25 am
the signal will be louder than the hiss so it will get buried. Ambient room noise will also burry it. I don’t think any tweeter will play any worse with a low level hiss.
I felt the same was myself. Then I started to think, if noise is coming from the tweeter that shouldn't be it has to be having an effect on what it produces when it does. Better to have the tweeter dead silent so when it has to do its job all its doing is its job.[/quote]
PostPosted: Sun May 20, 2018 6:28 am
Just play music and the sound will be drowned out by pleasant noise.
Try it!
PostPosted: Sun May 20, 2018 7:01 am
Most of us at place age here years old cannot hear above 15Khz, and some may not be able to hear above 13Khz...
Interesting read.
https://www.gcaudio.com/tips-tricks/system-noise/
www.leohl.ca
PostPosted: Mon May 21, 2018 12:10 pm
Mine are loud enough to hear from the listening position, but just barely.
Got Hi-Fi?
