It is currently Tue Aug 14, 2018 6:50 pm
Post new topic Reply to topic  [ 32 posts ]  Go to page 1, 2, 3  Next
 Post subject: phono cable
PostPosted: Tue May 15, 2018 7:54 pm
I;m looking for a phono cable that is better than the one supplied with the Dynavector DV507 mkII.
Any suggestions?
Furutech AG-12 perhaps?
 Post subject: Re: phono cable
PostPosted: Tue May 15, 2018 9:09 pm
well, welcome back and yes the Furutech is hard to beat for the price.....
PostPosted: Tue May 15, 2018 9:15 pm
You should really check out Wireworlds offerings. I have no experience with their tonearm cables, as none of my experience is with din connectors. But their other cables are amazing at noise rejection and preservation of signal, so their tonearm cables may be worth a look.
Davidson Home Audio Designs
PostPosted: Wed May 16, 2018 1:28 am
Audio Sensibility silver statement, great cable !!
PostPosted: Wed May 16, 2018 2:53 am
Mogami W2965
great cable...have built interconnects with this as well
PostPosted: Wed May 16, 2018 3:07 pm
Someone once wrote that change is easy; better...not so much. A change for the better would be to ditch the DIN plug and rewire the arm with a continuous loom. I can see why some would hesitate to do this.... it's not a cheap Rega afterall...
PostPosted: Wed May 16, 2018 3:18 pm
You're better than that, man. :wink:
PostPosted: Wed May 16, 2018 3:59 pm
Maybe, but not wealthier lol
PostPosted: Wed May 16, 2018 6:15 pm
Does anyone have first hand experience with the Furutech? if someone compared it to the Audio Sensibility, I'd be amazed.
BTW: Does anyuone know what the DV 507 mkii uses for it's phono cable/wire?
I heard that the wire is less than 37pF per foot, but for an MC cartridge, does that really matter? I have wire that is less than 37pF per foot capacitance but not 100% shielded. I don't see how one can achieve that low capacitance and still have good shielding -- unless the wire is very very thin I guess....
As for a continuous loom, the arm has a detachable headshell. You'd only save one connection point.
PostPosted: Wed May 16, 2018 6:32 pm
One of three that can be avoided, but I guess 30% is not enough to bother chasing, especially since it isn't the worst 30%.
I consider 37pF to be pretty high for wire these days, but probably not high enough to matter with MC. As for which brand is best I'd say it's a crapshoot. Pick a budget and design that appeals to you and roll the dice.
PostPosted: Wed May 16, 2018 6:55 pm
I own one of these and am extremely pleased...
http://www.canuckaudiomart.com/details/ ... -2900-srp/
I Put A Spell On You!!!
PostPosted: Fri May 18, 2018 4:40 am
I've used the Cardas 34awg clear tonearm wire, the twisted quad version
http://www.cardas.com/34awg_clear_tonearm.php
It is a little tricky to work with, but the fiber jacket and the litz configuration are key features to reduce the effect of the wire on the signal.
PostPosted: Fri May 18, 2018 6:15 am
What? No pictures? I'm not buying it! :lol:
PostPosted: Fri May 18, 2018 2:55 pm
That's very dear. I've got to send my kids to univ, and the pockets are no so deep.
PostPosted: Fri May 18, 2018 3:15 pm
Libor's suggestion is the go to so far. I'm sure he knows...
Users browsing this forum: Google Adsense [Bot] and 2 guests
