It is currently Tue Sep 18, 2018 10:59 am
PostPosted: Thu Apr 26, 2018 5:46 pm
Anyone ever use these ? Intriguing for the price
http://stores.ebay.ca/AUDIO-AMPLIFIER-SURGERY-AND-PARTS
PostPosted: Thu Apr 26, 2018 6:13 pm
If ever you buy some, please report back.
PostPosted: Mon Apr 30, 2018 10:36 am
Interesting, and rather cheap. I wonder if their "naim" speaker cables actually match the specs of actual Naim cable as they are advertising it as "Naim" speaker cables.
edit: hmm, it says they are. Interesting indeed.
Got Hi-Fi?
PostPosted: Mon Aug 20, 2018 12:03 pm
I bought a couple pairs a few years ago as part of the cable quest. I have since moved along, but was happy with them and a couple "critical listener" friends also liked them. I do not remember them having any noticable signature.
I gave a pair to someone who has an above average small system, but he is not an "audiophile". He thought they improved upon his stock cables.
It would be interesting to plug them back into my system and see how much $200 - $400 cables have actually improved the sound.......but probably will not get around to it.
I will send you a personal message.
PostPosted: Fri Aug 24, 2018 10:49 am
My curiosity got the better of me and the Amplifier Surgery RCA cables are back in the system. For context, my current favourite cables are Morrow MA4's with silver bullet plugs, but usually these are not affordable. A couple prominent brands that I have not heard are Cardas and Wireworld.
This 4 foot pair has the Amphenol plugs and the shielding is grounded through external wires, similar to phono cables. I have put a single quick disconnect terminal on both ground wires so that they can be grounded through different connectors. In this case they are plugged into a ground receptacle on a power bar. This probably makes no difference, but the ground wires emerge from the ends of the cables which are closest to the source component.
They connect a TEAC PD H600 CD player to a NAD C 165BEE preamp. The preamp connects to Emotiva XPA-100 monoblocks with Ultralink Platinum Mark II, cables. The speakers are Axiom M80's and the speaker cables are unterminated 27 foot lengths of standard oxygen free, fine stranded, 10 AWG wire. The speakers are rolled off at 70 Hz and the lowest bass is taken up with a Tannoy 10" subwoofer that is connected with a Take 5 Audio cable. In my opinion, the subwoofer is too small for this duty, but it doesn't know it! The Axioms are big and too close to the corners of the room, but that can not be helped.
Amplifier Surgery cables: They sound really good. I had sent a PM to the OP, and offered to sell them. Now I am not so sure that I want to sell them! They are musical and have lots of bass and detail. In this system they might sacrifice a bit of bass and detail compared to Morrow MA3's, but they are not as bright and are easier to listen too. To me, they are just a tiny bit bright but it might be my system.
This is the best sound that this CD player has ever generated through it's analogue outputs. I have 2 stereos and regard this stereo as the second system. Roy Hargrove's Emergence CD now sounds more musical through this "second system" than it has ever sounded in either system. The brass instruments are especially natural and full sounding.
My systems have changed and improved since these Amplifier Surgery cables were first used, and I have tried quite few different cables in the meantime. Now I am not sure if anything was accomplished with many of the cable swaps. I see that these cables are now offered in more configurations and with Cardas plugs as well as the Amphenols.
The Ultralink Platinum Mark II's are also a happy rediscovery. Their sound is rich, and bassy in this system, but there is also lots of detail. This system tends to some sibilance and the Ultralinks mostly cured that. The Amplifier Surgery cables and the Ultralinks seem to be a very musical combination. One cabling theory is the "complete loom from a single manufacturer". I have never had enough free cash at a single time to try that, so I mix and match as best I can. Sometimes it works.
Conclusion: These Amplifier Surgery cables are very good, especially for the price. I recommend trying at least one pair in a stereo. Different flavours aside, it would be difficult to do better without spending multiples of the Amplifier Surgery prices. These really are a great product and they deserve a positive review.
PostPosted: Fri Aug 24, 2018 12:39 pm
These look pretty interesting, but the shipping cost for a 10' pair is $75 - WTF?
PostPosted: Fri Aug 24, 2018 1:09 pm
I am not sure of the method of shipping, but if you are shipping a $200 order into the States by Fedex, that would be the cost.....
I am going to give them a try. I have ordered a set of RCA/XLR cables and will get a couple of pairs of RCA to RCA for my CD players. Let's see what they can do on a combined order and I will report on how they sound. I was impressed by the prices on all their custom cables. And the materials appear to be top flight.
PostPosted: Fri Aug 24, 2018 1:45 pm
I bought a 10ft silver plated 4 pin xlr cable for my Audeze LCD3 from Amplifier Surgery and I am very impressed with the build and sound of the cable. Really incredible value when compared to the competition for after market cables.
PostPosted: Mon Aug 27, 2018 12:44 pm
If you are serious, I suggest you email Hamad through his ebay site. He was responsive and VERY accommodating regarding the price and combined shipping. I am sure a serious offer would be considered. On my ebay site I have difficulty with some country's shipping rates. The result is a bulk, one-size-fits-all that is not unreasonable. I always look for a better price when combining orders and always quote the customer. I have flexibility. When I ordered three sets of cables, Hamad showed the same flexibility.
I'll report back when the cables arrive next week and I have a chance to test them. By the way, custom cable orders (like mine) only take a few days to make up.
I hope they sound as great as the service I got from Hamad.
Best, Tom
PostPosted: Mon Aug 27, 2018 2:13 pm
Experimenting further:
I swapped out the Ultralinks for a pair of Lavricable 14 Core Masterlines. While the Ultralinks have a deep bass sound, the Lavricables favour upper bass or lower midrange. They like trombones and saxes. In this system the Lavricables were a better compliment to the Axiom M80's which are also pretty bassy......and there was no return to sibilance. The Ultralinks better complimented another set of speakers that are light on bass.
I really like these Lavricables. To my hearing they are close to and comparable to Morrow MA 4's with bullet plugs, but possibly with a lighter sound. They are very clean and detailed
http://www.lavricables.com/cables/master-full-silver-rca-interconnects/
PostPosted: Wed Sep 05, 2018 1:41 pm
Here is a little update. I ordered three sets of cables. Two sets are RCA-RCA, the other being RCA to balanced XLR for a pair of monoblocks I am building. Anyway the cables arrived 6 days after ordering, Arrived from the States by mail (No HST, No duties) I have a bedroom system (Nakamichi MB8 to Marantz 1550 to Mission 753s. I like the sound, nice, smooth, revealing. I was using Nordost White lightnings....I swapped in the 1 foot Amplifier Surgeries......WOW. :shock: MUCH more revealing, spacious and I had to turn down the treble. The mids are amazing. Bass even seems slightly more prominent.
OK, I thought, this must be good old placebo effect. So I swapped out and installed a set of AQ's I had lying around. Nope, the Amp Surgeries are that much nicer. I am an English Speaker kinda guy, liking rich midrange and clean highs. I thought I had a great package with the Nordost.....
I have found my new "best cables"........
And I paid $172.00 all in for three sets!!!
:D :D :D :D :D :D :D :D :D :D :D :D
PostPosted: Thu Sep 06, 2018 6:38 am
I absolutely agree. These cables really punch above their weight. Seriously good sounding cables. With shipping, my three cables cost about $60 a pair!! And I agree that they are a bit bright....I just backed off the eq on the treble and bass, and the mids are lush and fulfilling, with "real" sounding highs and lows. When you hear individual string plucks, the decay of the note, the rasp of the sax reed, you know you have great synergy in your system. And that is what I have with these cables.
I am ordering a couple more pairs for my main system....
Best, Tom
