It is currently Thu Aug 16, 2018 9:29 am
Post new topic Reply to topic  [ 56 posts ]  Go to page 1, 2, 3, 4  Next
PostPosted: Tue Apr 24, 2018 4:40 pm
I was doing an A/B power cable test with my Cyrus One - the unit had the power turned on in the front and an input playing. I unplugged the cord and plugged in the new one without turning off the power at the front :shock: the unit powered off and won’t power back on. Any ideas ? I’m devastated
 Post subject: HELP!!!
PostPosted: Tue Apr 24, 2018 4:42 pm
PostPosted: Tue Apr 24, 2018 4:51 pm
Have you checked fuses in the back of unit?
 Post subject: Re: HELP!!!
PostPosted: Tue Apr 24, 2018 4:52 pm
Check fuse.
I Put A Spell On You!!!
PostPosted: Tue Apr 24, 2018 4:59 pm
There's a fuse in the IEC socket, probably blown. If not that one, there are a couple of fuses in the amp. Check those.
Dan Santoni
PostPosted: Tue Apr 24, 2018 5:04 pm
No visible fuse at back of inside? But can’t tell without removing cover?
-- 25 Apr 2018 01:04 --
No visible fuse on the socket?
PostPosted: Tue Apr 24, 2018 5:05 pm
Where is it?
PostPosted: Tue Apr 24, 2018 5:08 pm
https://www.hifiengine.com/manual_library/cyrus/1.shtml
PostPosted: Tue Apr 24, 2018 5:10 pm
fuse appears to be directly to the right of the power switch on the rear
from the pics ive seen...
PostPosted: Tue Apr 24, 2018 5:14 pm
Mine is the newer “The One”
I don’t see a fuse location? Do all amps have a fuse somewhere? I am praying tes and that’s all it is:
http://hifipig.com/cyrus-one-integrated-amplifier/
-- 25 Apr 2018 01:23 --
PostPosted: Tue Apr 24, 2018 5:20 pm
Sorry not familiar with these so I googled the manual.
If the one I read is correct it says there are no user serviceable fuses.
PostPosted: Tue Apr 24, 2018 5:25 pm
What does that mean - did I fry the unit? Are there internal fuses?
PostPosted: Tue Apr 24, 2018 5:33 pm
I'm sorry, I don't know any more about it than that.
But from the way it is worded I would guess there is some form of protection inside.
They didn't say no fuses, but specifically, NO USER SERVICEABLE FUSES.
