It is currently Mon Jul 16, 2018 6:39 am
Post new topic Reply to topic  [ 54 posts ]  Go to page 1, 2, 3, 4  Next
PostPosted: Fri Mar 30, 2018 1:57 pm
Says it all guys.
I sat down and put on an album and it played for around 1 minute with no problem and then the sound cut out.
The power to the equipment is good and I unattached cables and power plugs and reattached everything.
Don't get it.
I have a simple system....NAD 356 BEE amp, Tube-box S phono-stage and a Gold Note Valore 425 Plus.
I listened all week and last night and everything was totally fine. Then this.
Any ideas ?
Thanks as always.
BTW...when I turn the volume button up, there is literally no sound until I get to roughly "7" on the knob and a crackling high pitch comes out while the turntable was trying to play an album...other than that, all silence.
PostPosted: Fri Mar 30, 2018 2:14 pm
Can you play another source like a CD ? This might tell you if amp is the issue.
PostPosted: Fri Mar 30, 2018 2:15 pm
Check your tubes?
www.leohl.ca
PostPosted: Fri Mar 30, 2018 2:18 pm
Check that the speakers cables at the speaker and the amp end are connected tightly. Hopefully you can get it solved and have a cold one.
PostPosted: Fri Mar 30, 2018 2:20 pm
What input are you using on the NAD 356 BEE?
www.leohl.ca
PostPosted: Fri Mar 30, 2018 2:21 pm
Not sure on model but blue light or red protection?
Any other source to try? Maybe sumthin other than nad?
PostPosted: Fri Mar 30, 2018 2:23 pm
Sounds like a dirty switch like the tape monitor.
PostPosted: Fri Mar 30, 2018 2:24 pm
Always have a back up system :D
PostPosted: Fri Mar 30, 2018 2:26 pm
Don't have another source other than my phone with a Bluetooth connection for the amp.
I just tried it and no sound at all.
I could replace my amp with an old Pioneer receiver and see what happens.
edit: thanks btw
-- 30 Mar 2018 22:28 --
I haven't changed anything at all since two years ago when I bought the amp...always use AUX.
Not sure why I bought an integrated amp lol because I am a one-dimensional record playing guy.
Oh, the tubes look to be normal, nice orange glow.
Thanks Ohms
-- 30 Mar 2018 22:29 --
First thing I thought of was a wire loose, causing a short. I did move one speaker slightly a week ago, um, er, to put up a Neil Young poster behind it. (lol) .... everything seems tight in the connectors.
Having a cold one now, that's how I troubleshoot best.
-- 30 Mar 2018 22:31 --
Hi Binky the Cat....it was red at first indicating an overload? on the NAD.
Then it stayed on solid blue. It was only red for under a minute.
Really weird.
Maybe I have to let it cool down for a few hours?
Thanks
-- 30 Mar 2018 22:32 --
Hi, I don't use a tape deck or the tape monitor switch...could that still pose a problem?
Damn you guys with back-up systems..... :wink:
I know, I know.
Wife, doesn't care, doesn't care.
PostPosted: Fri Mar 30, 2018 2:34 pm
Did you try picking the amp up and shaking it?
PostPosted: Fri Mar 30, 2018 3:04 pm
drywhitetoast is down.
When it stopped playing was there any whiff of electronic burnt vapour in the air? I am pretty sure you are going to find it is the amp - probably a power supply failure. It will be fixable if put it in the right hands.
PostPosted: Fri Mar 30, 2018 3:13 pm
Maybe you blew a fuse in your amp. You may want to check the fuse visually to verify it is good. It's a possibility.
PostPosted: Fri Mar 30, 2018 3:21 pm
Yes dwt check your fuses!
PostPosted: Fri Mar 30, 2018 3:26 pm
buybye88 wrote:
No David, no burnt smell. Thanks
-- 30 Mar 2018 23:27 --
Thanks Chip and Moon.
Will do that tomorrow.
Gonna' watch the Leafs and chill.
Thanks to all for your support.
Will update for sure.
Again, this is a great community.
Told my wife that within 10 minutes roughly I had so many helpful replies.
You guys are the best.
Go Leafs Go
PostPosted: Fri Mar 30, 2018 3:32 pm
There is a fuse by the transformer. Try switching the soft clipping to off. Check your speaker cables, binding posts at your amp and speakers for shorts.
Users browsing this forum: BEAVERMAN, Blake, bolly, Google Adsense [Bot], turnmeup and 14 guests
