It is currently Sun Jul 22, 2018 10:16 pm
PostPosted: Thu Mar 22, 2018 9:22 am
Hi I am hoping someone has some insight to my issue.
I was running a multi zone setup and just last week zone 2 stopped working.
I am running the latest firmware and I have tried the following:
1)Re-initialized the microprocessor with nothing plugged in.
2)Tried using component out instead of HDMI
3)tried brand new HDMI cables.
4) I have even tried a completely different TV for zone 2 than the one I was using.
5)tested all the same above with zone 3 and no issues.
There don't seem to be many other settings that can be changed.
There is no audio or video out of zone 2 what-so-ever.
PostPosted: Thu Mar 22, 2018 10:15 am
try running setup again. Zone 2 must be enabled and (somehow)it may be disabled. Check it again. You could call Denon, but I have pretty much given up trusting they know anything about their own products. I found that out when trying to pre-out a downstream amp.....I was surprised the guy at the other end of the phone could find his desk, let alone answer my questions.
My bet is that the zone is disabled.
let us know please.
PostPosted: Thu Mar 22, 2018 10:19 am
The user interface is about as simple, for a Denon, as the support agent you described.
I have gone through the configuration about 6 times now and there doesn't seem to be a way to disable the zones. You can turn them on and off with the power button but still just a blank unsatisfying screen...
PostPosted: Thu Mar 22, 2018 10:28 am
Hmmm I had a similar problem with an X-2200. It was zone disabled. Have you checked the on-line user guide? There are trouble-shooting (albeit basic) instructions. Methinks it is time to call the simpletons...
Good luck! :?
PostPosted: Thu Mar 22, 2018 12:32 pm
Make CERTAIN that zone 2 is "turned on" and that you don't have the amp setup for your 7.1 (vs 5.1)
I've been tricked many times using zone 2/3 on my denon 4806 amp. Usually if I can find the denon remote, I can scroll thru using the amp button to zone 2/3 and turn it "on" and make sure the volume is turned up. (as well as ensure the correct source is selected)
It can be confusing as hell, but when it works, it works great. :) And I suspected you checked this, so just throwing my 2c in to the hat. :D
PostPosted: Thu Mar 22, 2018 12:48 pm
you could try downloading the phone app from google play and turn the zone on that way.
PostPosted: Thu Mar 22, 2018 3:13 pm
I'll try both the phone app as well as make sure it is setup for 5.1. Possibly misses setting it to 5.1 post factory reset.
