It is currently Thu Apr 19, 2018 5:52 am
PostPosted: Mon Mar 19, 2018 1:11 pm
Hi
I bought some speaker spikes but the insert are in M8 while my spikes are n M6. Since I can't return it I need to find a solution to use them.
Do you have any solution (adapter, metric size insert, etc)? I take a look at Home Depot but the don't have metric size insert.
Thanks
Frederic
PostPosted: Mon Mar 19, 2018 1:35 pm
Get some M6 nuts and fasten them to your M8 inserts.
JB Weld or Gorilla Glue.
PostPosted: Mon Mar 19, 2018 2:21 pm
Might be easier to sell the spikes and move on... However, if you're looking at adapters (and many exist, though you're not going to find them at places like Home Depot), you better check the thread pitch as well. M8 is not enough. There are M8 available with 1.25, 1.00, and 0.75 mm thread pitches. Don't assume anything!
Good luck, Dave
PostPosted: Mon Mar 19, 2018 2:38 pm
What am I missing here? This isn't that complicated. Why not just buy the correct spikes and keep or sell the other ones? :?
PostPosted: Mon Mar 19, 2018 2:52 pm
go see solen in st-hubert
PostPosted: Mon Mar 19, 2018 3:19 pm
Ok I understand...it is for sale and I will buy some M8 size spikes.
PostPosted: Mon Mar 19, 2018 3:38 pm
Now I am really confused. Are you the original poster with a second CAM ID, or are there two members from Montreal with the same spike issue? :wink:
PostPosted: Mon Mar 19, 2018 3:53 pm
I am the same...saved password (on my conputer is different from my cell phone). I need to remove one user.
PostPosted: Mon Mar 19, 2018 4:15 pm
Fredlx wrote:
Hi
Thanks
Frederic
Adapters do exist to convert sizes up or down or from metric to SAE but they will cost more than your spikes.
George
Users browsing this forum: Google Adsense [Bot], hollinger, Linus1, Reckoner, siver, yakbikeski and 22 guests
