It is currently Sat Apr 21, 2018 1:11 pm
 Post subject: Rogue RP1
PostPosted: Thu Mar 15, 2018 4:27 pm
I am supposed to go to listen to a Rogue Rp1 preamp tomorrow and I may purchase it. My question is that it seems to have a low output rating. The spec says rated output 1volt. I need about 1.2 volts to drive my ST70 amp. Does anybody know if this rated output is the maximum out ther is no reference in the specs to the input to get 1 volt out. Is it really that low.
Thanks
 Post subject: Re: Rogue RP1
PostPosted: Thu Mar 15, 2018 4:37 pm
There is also the gain of the linestage (7dB) to consider. Not that I would know, just posting it as more info for those who do.
PostPosted: Thu Mar 15, 2018 5:24 pm
I suggest you read this article about line level signals.
https://en.wikipedia.org/wiki/Line_level
And yes, the pre-amp you are considering is a bit low, but not crazy low, and it will drive your ST70, but will perhaps require a bit higher volume setting than usual. 1.2 volts into the ST70 would probably induce clipping - a bad idea for speaker health, although those old ST-70 driver tubes can take quite a lickin.
PostPosted: Thu Mar 15, 2018 5:27 pm
I would suggest you contact Rogue directly. They actually answer the phone or your emails! I have both the Rogue Magnum 99 preamp and Rogue Stereo 100 and could not be happier. I have had the Rogue pre for 10 years...that should say it all.
PostPosted: Thu Mar 15, 2018 5:30 pm
+1
1.2v is the max voltage accepted. As David said, the Rog RP1 will easily drive your amp.
1/1.2 = 83%
I guess you don't run your system with volume higher than 83%, then you are good to go.
PostPosted: Thu Mar 15, 2018 5:52 pm
It's true. I am also impressed with their customer service! Call them (or email) and they will gladly answer all of your questions.
Joe Bonamassa, 2014
PostPosted: Sun Mar 18, 2018 2:57 pm
Thanks for all the input. Picked up the RP1 ‘this weekend and have it up and running now. Love the sound so far and I’m sure it will only get better with time. It also drive my ST70 well.
Thanks for everybody’s help
PostPosted: Sun Mar 18, 2018 3:12 pm
Congrats and enjoy! Very nice built and sound. Love my Tempest III.
Joe Bonamassa, 2014
PostPosted: Sun Mar 18, 2018 3:21 pm
congratulations
PostPosted: Sun Mar 18, 2018 4:18 pm
Congratulations!
PostPosted: Sun Mar 18, 2018 4:28 pm
I too found them to reply to emails very quickly.
If only they can find a way to get the RP5 I ordered back in late December here faster.
PostPosted: Sun Mar 18, 2018 6:36 pm
Great news man.
Enjoy 8)
Users browsing this forum: Fidius123, sound addiction and 10 guests
