It is currently Fri Jun 22, 2018 5:15 am
PostPosted: Sat Mar 10, 2018 7:56 pm
I'm trying to set up a telefunken w250 (same as PE 2020) idler drive turntable using the instructions in the user manual.
The problem is that the needle does not lower enough, and this happens in both manual and automatic modes. The arm lowers a bit, and then comes back home.
It was working fine before changing the cartridge and readjusting the counterweight/anti-skate.
What could the issue be? Thanks.
PostPosted: Tue Mar 13, 2018 3:39 pm
Does anyone have any experience with this turntable?
Or may know how to fix the issue?
PostPosted: Tue Mar 13, 2018 5:13 pm
You may have more luck posting in the Dual forum at http://www.vinylengine.com. There are experienced Dual/PE specialists there.
There ain't no such word as "vinyls".
