It is currently Fri Jun 22, 2018 5:17 am
Post new topic Reply to topic  [ 27 posts ]  Go to page 1, 2  Next
PostPosted: Thu Mar 01, 2018 10:30 pm
A care package arrived yesterday, and I started the layout tonight...
28337485_10155518101802741_6787887733066565155_o.jpg [ 299.06 KiB | Viewed 1287 times ]
28337704_10155525507722741_5486898635125296950_o.jpg [ 258.1 KiB | Viewed 1287 times ]
PostPosted: Thu Mar 01, 2018 11:39 pm
Is your build going to be similar to the Overnight Sensation MTM design?
PostPosted: Fri Mar 02, 2018 4:23 am
I think the Overnight unit uses smaller drivers, I will be using two 7" bass drivers and the box will not be ported.
David.
PostPosted: Fri Mar 02, 2018 5:49 am
I can't wait to see how they turn out. The Dayton kits seem to be pretty on point for the price. I'm seriously considering building one of their subs (possibly just with the cab and switching out for my own pro drivers).
PostPosted: Fri Mar 02, 2018 6:33 am
Watching this with great interest!
NON-ported kits are few and far between.
Good luck, and look forward to your progress.
del Sol
PostPosted: Fri Mar 02, 2018 6:49 am
Where does this kit come from?
PostPosted: Fri Mar 02, 2018 8:06 am
Subscribing to this thread. I am very interested in both parts sourcing and design. I have found little in the way of reasonably priced materials in Canada. Good luck with your build.
I like gear and good sound but in the end it’s all about music.
PostPosted: Fri Mar 02, 2018 10:47 am
Parts Express, has some kits, not sure if the OP's kit is from there, see link below:
https://www.parts-express.com/cat/speaker-kits/286
PostPosted: Fri Mar 02, 2018 1:20 pm
Do you have a Jasper "Precision Circle" Jig?
www.leohl.ca
PostPosted: Fri Mar 02, 2018 5:59 pm
While I did buy all the parts from Parts Express, it was not a "kit".
PostPosted: Fri Mar 02, 2018 7:59 pm
About 2 cubic feet per side?
Duratex is about the easiest finish. Just a sponge roller. Q-components up here.
PostPosted: Fri Mar 02, 2018 9:45 pm
About .9 per side. Two feet would be for ported. I have bought Duratex from Q before, thanks.
The face with the drivers will be Duratex, not sure if I will veneer or plastic laminate the rest of the box.
David.
PostPosted: Fri Mar 02, 2018 10:01 pm
Hi David,
what crossover point did you choose ?
PostPosted: Sat Mar 03, 2018 6:30 am
Just curious, why did you not purchase the parts from Solen?
www.leohl.ca
PostPosted: Sun Mar 04, 2018 12:19 pm
Ship to the boarder and pickup was cheaper.
-- 04 Mar 2018 20:21 --
I cut the sides and tops so far today.
Attached reinforcement strips to the sides where they will meet the baffle and get a heavy round over.
Biscuits are are for alignment so they don't slide all over the place.
28516391_10155532721352741_7854851660366396883_o.jpg [ 249.4 KiB | Viewed 797 times ]
28468356_10155532317952741_5832785258365321216_o.jpg [ 307.27 KiB | Viewed 832 times ]
28472303_10155532317002741_1349173622811394048_o.jpg [ 493.7 KiB | Viewed 832 times ]
Users browsing this forum: Frank Wang, juno and 1 guest
