It is currently Sat Sep 22, 2018 2:40 am
PostPosted: Sun Feb 25, 2018 2:01 pm
I reconfigured my upstairs 2-channel system today, and when I went to fire things up, the PowerCenter started to emit an alarm. Everything was working well last night.
I opened it up to see if something would be evident. Looked fine.
There is a circuit breaker on the back of the unit, but it seemed fine. The 'wiring ok' and 'ground ok' lights come on, but that is it. There is no power at the outlets.
Without getting into a debate about surge protectors etc., is there and easy and inexpensive repair for this unit?
I like the fact the PowerCenter sequences (time delays) the outlets so that my power amp is the last thing to turn on, and first thing to turn off.
Any help would be appreciated.
Thanks,
Doug
PostPosted: Sun Feb 25, 2018 2:41 pm
Do you have the same issue with nothing plugged into it?
Manual, LED's page 17, troubleshooting page 21.
https://www.parts-express.com/pedocs/manuals/185-165-monster-cable-manual-41868.pdf
www.leohl.ca
PostPosted: Sun Feb 25, 2018 2:53 pm
varistor shut (little blue disc on the left side)
very commun on the monster power...sold mine many times ago
PostPosted: Sun Feb 25, 2018 3:28 pm
Yes, it sounds an alarm as soon as power is supplied to the unit.
The first 2 lights are green (OK), then nothing. Methinks she might be done......
PostPosted: Sun Feb 25, 2018 4:02 pm
I owned an HTS 5100 that died after about 4 years. Poor reliability led to them to discontinuing their power centers.
Frankly, Monster products are IMO junk. Avoid.
PostPosted: Sun Feb 25, 2018 4:25 pm
Can't help with that Q,Years ago used a monster surge protector(connected to my computers).
short story,they didn't protect ****,computers were toast after power surge.
After the shityatas went Torus PUI's( .....end of story,have used Torus for yrs and all's well.
They are the only component I will not sell.
Users browsing this forum: Google [Bot], Google Adsense [Bot], planet10 and 2 guests
