It is currently Sun Jun 24, 2018 4:48 am
PostPosted: Thu Feb 22, 2018 1:02 pm
hey guys. i have a Runco CW-50mc and i have no idea what it's worth. is it worth keeping? selling? I know it was $9000.00 USD in 2003 but now...who knows?
should i keep it?
PostPosted: Thu Feb 22, 2018 3:22 pm
At these times where the 4k is now available, we can say that 720 pixels for 50" is obsolete.
Doesn't worth it.
PostPosted: Thu Feb 22, 2018 4:50 pm
Additionally, Runco is no more. So keep it and enjoys beacue the $250 you might get will not be worth it.
PostPosted: Thu Feb 22, 2018 5:13 pm
Unfortunately, its not worth much at all.
Fortunately, it would probably still smoke any new box store 50"
I'd keep it and enjoy it!
Davidson Home Audio Designs
PostPosted: Thu Feb 22, 2018 7:57 pm
If it still works well I would probably keep it. If you sit far enough away 720p (or 1080i) is still quite watchable and the Runco plasma tv has a nice picture. I am going to keep my Samsung 60" (1080p) plasma for a long time (hopefully).
I also have two Mitsubishi hc5 projectors (1080p) that, with extra bulbs, should last me for quite some time as well. I am sure 4k is better but I am satisfied with my current tv's. There is more to a picture than just resolution.
PostPosted: Thu Feb 22, 2018 8:12 pm
Amen to that! When I want to watch a blu-ray, I go in the basement & rock my Pioneer 720P plasma. Component cable (yes I said component cable) has a greyscale & color accuracy on this TV that I just cannot believe. It also renders optical depth of field beautifully. You can literally sit there & call the lenses shot-by-shot, 50mm, 85, 28, etc. If it ain't broke, use it.
8)
