It is currently Mon Jun 18, 2018 7:03 am
 Post subject: Playing Benchmark DAC
PostPosted: Wed Feb 21, 2018 1:48 pm
This is a long overdue...now as a warm up project as I'm working on a DAC project for a friend and need do some delicate stuffs to warm up a bit...
Anyhow, here is the DAC, I'm planning to restore it first, then probably will play some mods necessary...
-The shiny caps on board are all Aluminum electrolytic...SMT
-power filter caps are Panasonic FK series, biggest ones are 1000uf/50V * 2 , plus 1500uf/16V * 1...FK has lower impendance than FC series
-the 2 * 330uf/25V closer to the voltage regulators seems are Nichicon caps
 Post subject: recap...
PostPosted: Wed Feb 21, 2018 6:04 pm
caps on the board replaced...
-Caps have lifespan, so have to replace those caps;
-You can see big areas of copper on the board, e.g. GND areas....solder iron better has some power...
-Don't use brute force to remove the SMD caps ever (even though this DAC's PCB quality is pretty good)
saw signal pass through Panasonic HA 1000uf/6.3V parallel with 4.7uf(probably MKT), quite unusual, replace them with 2.2uf MKP (those 2 "white box") for now...
Yeah, nothing fancy here. I used some Rubycon ZLH, ZA to replace Panansonic FK/HA ones mainly in the digital area as I have some handy...in analog area, used some Elna SilmicII, coupling used MKP2(later on might change to some better ones ...dame the chassis is tiny and can't fit big ones;-)
Big power filter caps plan to use Elna LAO 2200uf/50V(the actual voltage after bridge rectifier is around 32V, so using 35V caps is ok here)...
File comment: "home made" SMD cap...;-)
File comment: caps removed, and solder pads cleaned...
File comment: All caps except 2 main power filter caps replaced...
PostPosted: Wed Feb 21, 2018 6:26 pm
As usual, you make excellent work.
Thanks for sharing. :)
PostPosted: Wed Feb 21, 2018 6:52 pm
The 2 main power filter caps need some final decisions to make...and probably will be positioned and put in after modding...
Since changed so many caps, just put in 2 * 4700uf/35V for now, and do some quick test...
PostPosted: Wed Feb 21, 2018 8:59 pm
Nice work as always, Frank!
PostPosted: Thu Feb 22, 2018 3:26 am
Thank you guys.
PostPosted: Thu Feb 22, 2018 5:16 am
Great work.
Looks like you have very steady hands for the delicate soldering!
PostPosted: Thu Feb 22, 2018 2:49 pm
all above were warm up for below...
adding 12 small parts has been done as part of dam1021 vref mod...
PostPosted: Fri Feb 23, 2018 5:08 am
Very impressive, it is really tidy. It looks like out of the factory.
PostPosted: Fri Mar 16, 2018 5:35 pm
Done...
friend provided a small chassis, but lovely;-)
File comment: hand-made a piece of SPDIF input board...parts connected by using their own "legs"...
File comment: move the indicator LED to front panel...
Users browsing this forum: David P and 2 guests
