It is currently Thu Jun 21, 2018 9:49 am
 Post subject: Burson aux 1
PostPosted: Mon Feb 19, 2018 5:03 pm
Hi Guys
Just sold a Burson to a fellow camer .. so he called and said aux 1 not working with volume control / but 2 and 3 are fine
i'll bring it in to DTS audio ... but any ideas ??? is this a costly thing ?? or maybe faulty input selector ??
 Post subject: Re: Burson aux 1
PostPosted: Mon Feb 19, 2018 5:24 pm
MAYBE that's normal??
PostPosted: Mon Feb 19, 2018 5:47 pm
-- 19 Feb 2018 21:24 --
If it is a Burson integrated (note: wrong assumption on my part, Mr. Hi-Fi appears to be correct as I see reference to a direct power amp input on the net) or DAC/pre, all the inputs should function, so not normal at all.
What is the Burson piece (model #)?
It could be the input selector board, should not be huge $. I am sure Dan can figure it out for you.
PostPosted: Mon Feb 19, 2018 5:48 pm
No offense to Burson...chill.
Maybe it's like a unity pass through input.
Would be nice to know more info than a "burson"
PostPosted: Mon Feb 19, 2018 5:49 pm
Its the Pl 160 ... intergraded amp
PostPosted: Mon Feb 19, 2018 6:00 pm
Hmm.
There are versions with a home theater pass thru
PostPosted: Mon Feb 19, 2018 6:15 pm
Didn't mean to offend, I see your point.
You could be correct.
PostPosted: Mon Feb 19, 2018 6:19 pm
What is a unity pass through ?
PostPosted: Mon Feb 19, 2018 6:25 pm
Mr Hi-Fi appears to be correct, it is for direct hook up as a power amp, so it is at full gain (unity) and controlled by the preamp plugged into it.
PostPosted: Mon Feb 19, 2018 6:26 pm
It's an input that connects directly to the output, without going through the volume control or much else. It's usually to allow a 2 channel system to co-exist with a surround system. You have a pre-amp for your stereo listening, but by switching to the pass through, your surround system can take over your speakers for the front channel.
PostPosted: Tue Feb 20, 2018 7:20 am
What vivid2 has not mentioned, does input 1 produce sound at full volume (as in a pass though) or does it not work at all. If you connected a CD player, as an example, to a pass though input, it will still work – just no volume control. I do not recommend testing in this fashion.
Vivid2 – to test if input 1 is a pass though, connect a component that has volume control starting that the lowest volume then slightly turn it up. If input 1 is a pass though you will eventually hear it as you turn up the volume of the component you connected.
PostPosted: Tue Feb 20, 2018 7:44 am
Inputs are relay switches.Bottom right in pic.Might have a wonky relay.
Could try reseating those Molex connectors at the inputs also.
PostPosted: Tue Feb 20, 2018 7:46 am
Unplug the power first! :shock:
PostPosted: Tue Feb 20, 2018 7:50 am
Yup.oops.
aux 1 is power amp in...double oops on my part.
PostPosted: Tue Feb 20, 2018 8:56 am
Geeze
I thought we determined that input one is intended for pass through ....it's on the web
Users browsing this forum: chamb and 6 guests
