It is currently Sun Jun 24, 2018 4:37 am
PostPosted: Fri Feb 16, 2018 3:53 pm
Hello folks
Im currently running a moon 110lp with my vpi prime scout . Love the table its fitted with a ortofon 2m black. Love the detail it retrieves ,however im feeling that it lacks in the bass extension. I have a bryston 14bsst amp with a Bat vk 30 taking care of the front end . Cable is a audio sensiblity phono cable . Im sure there are products out there that can dig deep into the low frequencies equal to that of a digital source. The moon phono pre is a fantastic unit for detail and air but bass is taking a back seat as a result . My speakers are full range von schweikert audio. Im looking to get the bass i get from my cd'd and digital player . Im hopefully not in a pipe dream to attain this . What are your opinions with lp bass retreval ?
PostPosted: Fri Feb 16, 2018 5:39 pm
Are you comparing identically mastered CD's and LP's at the same volume level?
The reason I ask is that most remastered recordings sound more bassy because of the use of dynamic range compression. In other words there may be nothing wrong.
Second, I would look carefully at the specs of the cartridge and phono cable. MM's like the ortofon 2m black are fairly sensitive to the capacitance of the cartridge and phono cable. Ortofon recommends 150-300 pF for your cartridge. I had the audio sensibility cable and I measured it somewhere in the 150-200 pF range (unfortunately, I have misplaced my notes on the exact reading). Your phono stage comes with a default loading of 100pF, so you may be able to gain some advantage my changing the setting to 0pF.
That's all I can think of.
PostPosted: Fri Feb 16, 2018 5:53 pm
thats an interesting point .... very well explained im going to giv it a try ( setting phono to 0 )
Best regards ...
PostPosted: Fri Feb 16, 2018 6:22 pm
LP most likely high/low pass filtered at the mastering stage among other things.
PostPosted: Fri Feb 16, 2018 7:39 pm
Capacitance (total cable to stylus) for MM can really effect the sound, or cause loss in freq response. Have you measured the capacitance of the cables from stylus to phono pre? You need a capacitance meter and measure with cart leads off.
PostPosted: Sat Feb 17, 2018 7:37 am
So will to much capacitance cause it or to little ?
PostPosted: Sat Feb 17, 2018 8:06 am
Tried setting the capacitance to “0” no difference at all sadly ..
PostPosted: Sat Feb 17, 2018 9:09 am
are you certain the cart is set up correctly?
try lowering the VTA, that should give more bass response.
PostPosted: Sat Feb 17, 2018 10:11 am
I was set up by audio Eden personnel I’m hoping it would be correct but wouldn’t hurt to check i guess
PostPosted: Sat Feb 17, 2018 10:32 am
I recently got a Gold Note PH-1 phono stage and the bass that I get is very textured and deep. This is with a Denon DL-301mk2, Parks Audio Budgie 1254Cinemag SUT , ARC SP9 and a Bryston 4bst. I had to turn down the bass settings on both my GoldenEar Triton Two's and my Paradigm 2100 v2 sub to very low levels.
Cheers, Doug
PostPosted: Sat Feb 17, 2018 10:45 am
what is your CD player? It seems that you are comparing in wrong category....means your phono is not on par with the digital you have...
Another option would be the Schitt Audio analog tone controls. $150usd
I don't know if it goes before or after the phono but it also has a bypass switch for critical listening.
PostPosted: Sat Feb 17, 2018 12:27 pm
Three things. The Orto 2M series (I had a Bronze) tend to have a very lean bass. Try a Denon MC. Second, as noted by another poster above, the very deepest bass notes, which are available on CD, are generally filtered out for a vinyl master. If your cartridge has very high compliance and if a vinyl record is not dead flat the combination of very low notes and a warped record can induce very large woofer excursions, particularly with bass reflex designs. Third, in both dynamic range and frequency extension vinyl cannot match CD, even if analog can sound smoother and more realistically present in the critical mid-range.
PostPosted: Sat Feb 17, 2018 12:40 pm
buybye88 wrote:
I would add to this that the 110LP itself might not be helping either. I have one that I keep as a backup in case my daily driver breaks down and I wouldn't consider bass it's strong point. At least not in my system.
PostPosted: Sat Feb 17, 2018 1:15 pm
This is what I’m thinking now . The 2m black I’ve heard had great bass, maybe I need a upgrade to my phono pre... any opinions on one that has stellar bass depths ?
Users browsing this forum: Google Adsense [Bot] and 4 guests
