It is currently Mon Jul 16, 2018 6:39 am
PostPosted: Thu Feb 15, 2018 8:11 pm
Just wondering what other brands would be similar in sound as my Grado 125e but with much better comfort. Current using the L-cush pads with scotch tape mod and am quite happy. My Hifiman 400i are so much more comfortable with longer listening sessions but I prefer the brighter presentation of the Grados.
I'd be looking for something under $250 used. Would the G-cush pads significantly improve the comfort?
PostPosted: Fri Feb 16, 2018 8:30 am
Some of the Beyerdynamic models might not be quite as bright but definitely have better comfort. The g-cush pads are a bit more comfortable but really change the sound and to my ears, not for the better.
PostPosted: Fri Mar 16, 2018 7:19 pm
grados have a sound all to themselves. i don't believe you will find another set like that. perhaps a set of Beyerdynamic or a pair of Sony. Your price range will limit your choices. Comfort and Grados do not go hand-in-hand.
Rega Planar 3/Nagaoka MP-11/Technics SL-7/Grado Black/NAD C725BEE/NAD C545BEE/NAD 613/NAD PP2/NAD DAC1/NAD HP20/Totem Arro/Technics SL-MC7/Sony MDR-1000X/EE-MU Teak/Grado RS2/FiiO Q1 II/JDS Element
