It is currently Sat May 26, 2018 3:55 am
PostPosted: Fri Feb 09, 2018 2:51 pm
I'm in the process of rebuilding an Oracle Delphi mk1 , I will be mounting a new Jelco 750 D tonearm on a custom Delrin arm board. I would appreciate suggestions for cartridge's mm or high out put mc that will work with my Bryston 1B pre amp . Ideal budget is around 500 but may have room . thanks for your time and expertise .
PostPosted: Fri Feb 09, 2018 3:59 pm
Here's one vote for an AT150MLX if you can find it within your budget.
PostPosted: Sat Feb 10, 2018 1:32 pm
Thanks for the reply .
PostPosted: Sat Feb 10, 2018 5:03 pm
I love my Linn Adikt on that tonearm. Sounds smoother than my 2m Black, but still satisfyingly detailed. The third cartridge I use and like more than any other I've had on the 750 is the Denon 103R. You'd need s step up for that though.
PostPosted: Sun Feb 11, 2018 12:38 pm
Im seriously considering Orfton 2m line of cartridge's . The bronze with integraded head shell is very interesting . Any experience with this line ? I'm learning there is a lot to cartridge /tonearm matching . Thanks again for the great recommendations.
PostPosted: Sun Feb 11, 2018 12:52 pm
The Ortofon/Jelco is another pairing favoured well. My concern with the integral shell would be ensuring the overhang is correct.
PostPosted: Sun Feb 11, 2018 1:08 pm
I have the 2m Bronze with the 750 and it sounds really good. The bronze replaced the dynavector 20x2l that didn’t sound as good on that arm.
PostPosted: Sun Feb 11, 2018 2:10 pm
Further consideration , still liking 2m series but not into head shell . Thanks
PostPosted: Sun Feb 11, 2018 3:01 pm
I use a Nagaoka MP150 and MP200 on mine. They both work really well.
PostPosted: Sun Feb 11, 2018 3:53 pm
I purchased a Hana SH from Audio Eden. It was slightly more, but well worth it. This version works well with moving magnet inputs.
PostPosted: Tue Feb 13, 2018 3:10 pm
I have heard lots of praises for the Hanna, can I run that cart off a mm phono stage sufficiently ?
PostPosted: Tue Feb 13, 2018 4:35 pm
Yes. It is designed for that loading and out put. The low output version is meant for mc inputs. I’m using an LFD mm phono stage
-- 13 Feb 2018 19:36 --
PostPosted: Tue Feb 13, 2018 5:16 pm
I'm using a Denon 103 with my Jelco 750, my SUT was made for the 103 and sounds very nice/balanced. I definitely am curious about the Hanna carts though.
Users browsing this forum: dougroach, fifthbusiness and 3 guests
