It is currently Tue Aug 21, 2018 7:09 pm
PostPosted: Fri Jan 19, 2018 8:12 pm
the passive preamp has a stepped attenuator tonight the nob came off i prefer smooth non stepped attenuator is it possible to change it to non stepped attenuator while keeping the same quality of sound http://www.divertech.com/aslpassiveti2.html
PostPosted: Sat Jan 20, 2018 4:45 am
ive decided to get the knob fixed keep it the way it is sounds great
PostPosted: Sat Jan 20, 2018 8:33 am
My thinking is you would be best to keep the stepped attenuator volume control as far as sound quality.
PostPosted: Sat Jan 20, 2018 8:36 am
thats what going to do getting volume knob put back right away
PostPosted: Sat Jan 20, 2018 8:45 am
Get it fixed? Unless it's different from 90% of all other audio controls, it can only fit one way and there will be a small hole on the perimeter of the knob, with a set screw that's come loose. You gently push it back on then tighten it with a skinny allen hex wrench....
While you're at it, get some wooden knobs, they sound better....
