It is currently Fri Feb 23, 2018 2:29 am
PostPosted: Tue Jan 16, 2018 5:27 pm
I cant get sound out of an Oppo 105 connected to PefrectWave DAC by way of a coaxial rca cable from the digital out on the Oppo to digital in on the PWD. The PWD is connected to my pre with a pair of XLR out from analogue out.
Also, cant get sound from music on hard drive connected to a PC (by USB cable) running JRiver connected to DAC by USB cable and from DAC to pre by XLR right and left.
Can someone please help. Id be grateful.
PostPosted: Tue Jan 16, 2018 6:39 pm
Can no-one help with this?
PostPosted: Tue Jan 16, 2018 7:44 pm
did DAC ever work before?
ie. software/ driver [for hi-res files] used is correct, properly installed, for example.
not being cheeky, but is volume down on computer? or on 105, or pre-amp?
PostPosted: Wed Jan 17, 2018 5:40 am
Just got it. Bought it from here. Im trying to hook it up for the first time.
PostPosted: Wed Jan 17, 2018 5:56 am
Correct input selected and volume up on the Perfectwave?
PostPosted: Wed Jan 17, 2018 6:07 am
Yes.
I also tried a setup with an Esoteric DV 50. No sound. Is there a way i can determine if the PWD is outputting a signal?
PostPosted: Wed Jan 17, 2018 7:29 am
Is the coaxial/optical output on the Oppo set to bitstream ?
PostPosted: Wed Jan 17, 2018 7:49 am
Yes, bitstream
