It is currently Mon Jan 15, 2018 11:51 pm
 Post subject: Naim NACA5
PostPosted: Sat Jan 13, 2018 5:20 am
Just curious if anyone knows a source for bulk NACA5. I’m looking to put together a 6 metre pair. Thanks.
Decware SE84UFO2... Omega SAM's... TEO GC Liquid Cables... Audiosector Integrated... Auralic Aries Femto... Sonore Microrendu... Equi-Core 1200 Power Conditioner... .. Audioquest Dragonfly Red... Zavfino1877 power cord.
 Post subject: Re: Naim NACA5
PostPosted: Sat Jan 13, 2018 6:17 am
FYI 6 m pairs on audiogon right now. Never found a bulk source myself and if you do please post it.
PostPosted: Sat Jan 13, 2018 7:06 am
Francois at High End Audio Exchange will be able to help you out.
https://www.highendaudioexchange.ca/
PostPosted: Sat Jan 13, 2018 11:54 am
Any Naim dealer should be able to get it.
Davidson Home Audio Designs
PostPosted: Sat Jan 13, 2018 12:10 pm
I remember back in the day - it used to be rather affordable...
PostPosted: Sat Jan 13, 2018 12:53 pm
As others suggested, any Naim dealer can make or order custom lengths with the connectors you prefer on each end for you. If using Naim power sources, the Naim plugs seem to work best for Naim integrated and power amps but may not be the right width for the speaker end. I would suggest Deltron or Z banana plugs, if this is the case. Various companies make them.
You might also wish to post a wanted ad. I've purchased and sold many pairs of NAC A5 over the years via CAM. This might be a more affordable option for longer length you require.
